Re: MSD pro billet distributors and caps GRRRR
[Re: sixpackgut]
#1332746
11/09/12 02:50 PM
11/09/12 02:50 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
I have been beat over the head because of my constant bashing of the MSD dist so It must be your fault because only a few people ever have a problem
And what dist are you using Ray ?
[Re: poisondart2]
#1332749
11/09/12 03:14 PM
11/09/12 03:14 PM
Posts: 860 lancaster,california
johnnycuda
I haven't had any problems with mine,and I drive mine quite a bit as well as run it occasionally,in the 10 years its been installed,I've only put 2 cap/rotors on it,and there wasn't a issue,was just doing maintenance.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: slippery440]
#1332752
11/09/12 07:40 PM
11/09/12 07:40 PM
Posts: 2,091 Delray beach, Florida
Performance Only
I just spray a some dielectric grease on the inside to solve the rust problem. as far as the center carbon wearing out, i've never had that happen. I would say better that 90% of the engines that go out of here have MSD distributors in them.
machine shop owner and engine builder
[Re: jamesc]
#1332757
11/09/12 11:12 PM
11/09/12 11:12 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I'm starting to think that maybe I should change my cap and rotor. I have an MSD pro billet distributor, been running it for around 10 years and never changed either one. Still runs good. I'm not being a smartazz, I know some have issues w/ them. Mine looks rusty under the cap, but it runs great. Might as well put on a new cap and rotor while I'm freshening up the motor.
[Re: an8sec70cuda]
#1332759
11/10/12 12:01 AM
11/10/12 12:01 AM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
chip,if your motor is apart, how do your ez roll lifters look? i just got a set for my 580. are you going to rebuild them? how many street miles do you have on them? thanks, brian
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: jamesc]
#1332760
11/10/12 12:23 AM
11/10/12 12:23 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
anyone else notice the carbons disappearing?
Yes for me 2 caps a year 200 passes or so plus some driving. I think a larger plug gap makes it worse. Had 1 flat gone.
"Just a Bracket car dressed up like a streetcar"
[Re: jamesc]
#1332762
11/10/12 09:15 AM
11/10/12 09:15 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Weird, I ran the MSD pro billet for years with no problems.
