Re: would this be cool
[Re: sixpackgut]
#1332641
11/09/12 11:33 AM
11/09/12 11:33 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
YES! ![](/ubbthreads/images/graemlins/punkrocka.gif) That off a terminator?
[Re: Mr.Yuck]
#1332643
11/09/12 12:27 PM
11/09/12 12:27 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
would that little thing feed all that engine????
I was thinking it wouldn't but my Ford friend swears it would. I really dont know.
Chip, it's a eaton off a cobra. I port them for the ford guys
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1332646
11/09/12 12:49 PM
11/09/12 12:49 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
not a chance. It won't push enough air. You might get 3-4lbs of boost. That is designed for what?? 350ci? It would probably work on a 5.7 Hemi or a SB but on a Hemi? What cubic inch is it anyway?
[Re: Mr.Yuck]
#1332647
11/09/12 12:58 PM
11/09/12 12:58 PM
an8sec70cuda
Yuck...look at the pic again, that's a late model hemi he has it sitting on.
[Re: an8sec70cuda]
#1332648
11/09/12 01:09 PM
11/09/12 01:09 PM
Triple Threat
Renton Washington
They will push 8-10# in stock configuration on a 4.6 (289) Smaller blower pulley and 14-16# is common place. Unported 115-118 mph trap speeds are normal, Ported add 5 mph.
Should make a 5.7 run pretty hard, if you can get the piston to live. You need EFI to feed it though.
[Re: an8sec70cuda]
#1332649
11/09/12 01:19 PM
11/09/12 01:19 PM
Mr.Yuck
Brookeville, Md
ohh yeah, ok carry on should be fine.
[Re: sixpackgut]
#1332652
11/09/12 01:36 PM
11/09/12 01:36 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
was toying with the idea of using the lightning style with plenum opening on the top and modding it for a carb
The Cobra Eaton is an M112 (112 CI displacement), the newer GT500's (and maybe Lightnings?)are M122's. The GT500 blower inlet is on the driver side. I have an 04 Cobra and have a ported Eaton sitting on the bench awaiting install, do you work for a well known company Ray? 525-550 RWHP depending on fuel and boost is basically maxing a 112, the 122 is probably worth another 40-50, and more torque low as the inlet is alot larger.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#1332653
11/09/12 01:51 PM
11/09/12 01:51 PM
sixpackgut
Charleston
I do them for extra money to pay for my hobbie. With the stock pulley, my porting picks up 30hp and 30 tq about which is the same as what other local guys have picked up using Stegmeier. I'm just much cheaper than him. I'm going to find out what the lightnings ones are ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
