How fast have you been with 440 and untouched 906's?
#1332472
11/08/12 10:48 PM
11/08/12 10:48 PM
Weight's, gear ratio and stall will be relevant to the conversation as will camshaft selection!
Re: How fast have you been with 440 and untouched 906's?
#1332473
11/08/12 10:53 PM
11/08/12 10:53 PM
moparpollack
Lil Herman
Lil Herman
85086
Untouched and 440 but turbo charged.
[Re: joedust451]
#1332478
11/09/12 09:09 AM
11/09/12 09:09 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
11.87 at 112 mph in a 3700# cuda. 440 + .040", Ross flattops (pumpgas), 906s w/ a 3 angle valve job, 509/292 purpleshaft, Edelbrock performer rpm, 830 holley, 3.91 gears and TCI 10" streetfighter converter (around 3500 stall).
[Re: DoubleD]
#1332480
11/09/12 11:47 AM
11/09/12 11:47 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
1967 B-body, 1967 440 standard bore with six pack pistions 10.5 to 1, 590 soild lift mopar cam, Tm7 intake 850 holley, 4.10 gears, 3000 stall, manual shift, 906 heads with valve job, weight was 3780 with me in it went 11.56 @ 120mph, switched to 915s with valve job and went 11.19 best @ 125 mph.
[Re: cudaboy]
#1332483
11/09/12 04:41 PM
11/09/12 04:41 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
1974 duster (2600#) 727 with J converter TRW pistons app 13.2 comp .030 over stock bushed, shot peened, and polished rods. direct connection bolts. stock crank stock 906 heads 750 roller cam 286 duration 4.56 gear 14-31 goodyear slick super stock springs (2) 750 holleys tunnelram many many years ago ran 10.20's 9.82 with ported 906 heads
[Re: Mr.Yuck]
#1332485
11/09/12 05:44 PM
11/09/12 05:44 PM
Triple Threat
Renton Washington
11.80@113 in a '70 challenger NHRA stock eliminator cars are going bottom 10's with trick valve jobs on otherwise "stock" 906's
[Re: pittsburghracer]
#1332487
11/09/12 05:54 PM
11/09/12 05:54 PM
Posts: 3,210 robin hood country
deaks
robin hood country
John Was that the crane R286 cam ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Triple Threat]
#1332489
11/09/12 06:59 PM
11/09/12 06:59 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
[Email]11.80@113[/Email] in a '70 challenger
You mean those "not ported" "not acid-etched" $5000-up 906 heads?? Those are the farthest from untouched heads there are...
#1332491
11/09/12 07:08 PM
11/09/12 07:08 PM
deaks
robin hood country
Mick
Yes it was and I still have a couple of them with different centerlines sitting on the shelf.
My old motor had the R280 in it but was a bit of a dog because it lacked comp and converter. What RPM did you turn. I've got a rusty 286 I use to prop my garage door open. i bet yours sounded pretty good, certainly a good running combo. Mick
