915 heads with weird pipe plugs (???) #1332018
11/07/12 06:10 PM
11/07/12 06:10 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
I have a set of 915 B/RB heads that I was going to use on a budget build. One of them has 1/8" pipe plugs in both corners on the exhaust side (see pic, sorry about focus). Does anyone know why this was done or what they are for? I have a stack of B/RB heads and have never seen this before. Thanks. -Mike
Re: 915 heads with weird pipe plugs (???) [Re: WarEagle1] #1332019
11/07/12 06:11 PM
11/07/12 06:11 PM
Alabama
W
W
Alabama
Other pic.
Re: 915 heads with weird pipe plugs (???) [Re: WarEagle1] #1332020
11/07/12 06:42 PM
11/07/12 06:42 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Somebody's idea for air bleeds maybe for complete coolant fill????
joe
Re: 915 heads with weird pipe plugs (???) [Re: WarEagle1] #1332021
11/07/12 06:43 PM
11/07/12 06:43 PM
NJ
rth Offline
rth  Offline
NJ
Are they into water jacket?
Re: 915 heads with weird pipe plugs (???) [Re: rth] #1332022
11/07/12 06:56 PM
11/07/12 06:56 PM
Alabama
W
W
Alabama
I think they do go into the water. I'm kinda afraid to take them out because they look like they've been in there for 40 yrs; probably have.
Re: 915 heads with weird pipe plugs (???) [Re: WarEagle1] #1332023
11/07/12 08:07 PM
11/07/12 08:07 PM
scratchnfotraction Offline
it may be done to remove all of the casting sand from the inside passages in the head.
could be for removing air when filling coolant so it does not get steam pockets waiting for t-stat to open and burp the air out.
could be for an indust engine with a temp sender or water take off for heating up carb choke/intake.
could be for oil cooler return or supply maybe.
but,knowing what passage it taps into such as water/oil/exhaust would help.
my 77 452 heads with peanut plugs from a motorhome,has a pug on one end of the front driver side head,but smaller than those in your pics.
the spare 452 set I bought has the machined area but no plug on either of them, I cant seem to find the reason it is there either.
what yr are the 915 heads?
Re: 915 heads with weird pipe plugs (???) [Re: scratchnfotraction] #1332024
11/07/12 09:45 PM
11/07/12 09:45 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
..if they go into the water jacket, it looks like a good place for a pair of these at the back of an engine.
Re: 915 heads with weird pipe plugs (???) [Re: scratchnfotraction] #1332025
11/08/12 01:08 AM
11/08/12 01:08 AM
Alabama
W
W
Alabama
I believe all of the 915 B/RB heads are 1967.
Re: 915 heads with weird pipe plugs (???) [Re: WarEagle1] #1332026
11/08/12 01:24 AM
11/08/12 01:24 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I would be afraid to take them out. Grind them flat and paint if they bug you. I have not seen them either but my B/RB knowledge is slim.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: 915 heads with weird pipe plugs (???) [Re: WarEagle1] #1332027
11/08/12 12:41 PM
11/08/12 12:41 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I have one 346 head that has those pipe plugs, and have seen it on a 452 head at a swap meet before too.
I've never been able to figure out why, but it almost appears to be either a factory test or repair of
some kind
Never had an issue with the 346 head, used it for many years
Rich H.
Esse Quam Videri
Re: 915 heads with weird pipe plugs (???) [Re: ZIPPY] #1332028
11/09/12 04:32 PM
11/09/12 04:32 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Interesting. Nothing like that on my 915s.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 915 heads with weird pipe plugs (???) [Re: DynoDave] #1332029
11/09/12 06:37 PM
11/09/12 06:37 PM
dogdays Offline
dogdays  Offline
You may want to just ignore them, because some pipe plugs are not solid.
They look lke 1/8" pipe plugs, if you really want thm out, heat them up pretty hot and as they are cooling, apply paraffin to the outside. As the casting cools, it draws the paraffin in and makes it easier to get the plug out. Of course, then you have to have something else to fill in the hole!
R.
