Re: Summit crankcase evac system: proper way to install? [Re: Crizila] #1331448
11/07/12 07:05 PM
11/07/12 07:05 PM
Az
Crizila Offline
Crizila  Offline
Az
evac tube mount
Fastest 300
Re: Summit crankcase evac system: proper way to install? [Re: Crizila] #1331449
11/07/12 07:09 PM
11/07/12 07:09 PM
Az
Crizila Offline
Crizila  Offline
Az
I mounted my tubes at the suggested 45 degree angle and depth in to the pipe, but I capped off the leading edge of the tube to creat more draw at a lower exhaust flow ( my guess and not "indoresd" by anyone else ).
Fastest 300
Re: Summit crankcase evac system: proper way to install? [Re: Crizila] #1331450
11/07/12 07:44 PM
11/07/12 07:44 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
...with turbo muffs dumping in front of the axle.
That's the problem. Turbo mufflers are not straight thru mufflers. They create back pressure. You need to use a "straight thru" muffler for the system to work with mufflers.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Summit crankcase evac system: proper way to install? [Re: 68LAR] #1331451
11/07/12 08:05 PM
11/07/12 08:05 PM
Az
Crizila Offline
Crizila  Offline
Az
I thought I mentioned noisy . They work great with no mufflers at all. My car is not a street car. Only time it see's a quasi exhaust system is when I have to do a little T&T on the street. Personnelly, if I were driving a street car with occasional track time I would not go with an Evac system. Just a PCV system.
Fastest 300
Re: Summit crankcase evac system: proper way to install? [Re: Crizila] #1331452
01/07/13 10:24 PM
01/07/13 10:24 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Not to resurrect an older thread, but I have been doing some more thinking about this...I am not sure I totally understand the vacuum concept being mentioned- I thought having vacuum does not matter unless you are powering something with it? Or am I totally off there?
I ran a PCV on my street car last year, with no power accessories...I was going to run both breathers to evac in the headers, with Borla straight through mufflers...Am I standing at a disadvantage losing my pcv for this system? I guess all the vacuum talk kinda has me confused now
Re: Summit crankcase evac system: proper way to install? [Re: mshred] #1331453
01/07/13 10:55 PM
01/07/13 10:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the E-vac you are pulling a vac in the crank case
and the vac you are talking about is in the intake
manifold..... two different things
EDIT
A PCV is hooked to the intake vac so its working while
you are at idle and cruising but it closes at WOT
so you can keep it on there
Re: Summit crankcase evac system: proper way to install? [Re: MR_P_BODY] #1331454
01/07/13 11:52 PM
01/07/13 11:52 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Ok, makes sense now...DOH!
Re: Summit crankcase evac system: proper way to install? [Re: 68LAR] #1331455
01/07/13 11:53 PM
01/07/13 11:53 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I run Dynomax Ulta-Flo mufflers. At idle there is almost zero vacuum. At around 3000 rpm, the system is pulling around 5" of vacuum. It will pull that much on up the rpm scale. This is one of the reasons that I also run a pcv. It pulls at an idle and drops off at higher rpms. So I have some vacuum all the time.
Not questioning your method, but seriously trying to learn- by pulling vacuum from the crankcase at idle via the PCV, what is the benefit? Does the motor run cleaner/better?
Did you ever try without the PCV and just the evac to see what happened?
Re: Summit crankcase evac system: proper way to install? [Re: mshred] #1331456
01/08/13 11:10 AM
01/08/13 11:10 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Running a pcv will give you a vacuum, (negative pressure in the crank case). If I recall correctly, (it's been a while since I've researched this), with no vacuum, the underside of the piston acts like a "parachute" on the downward stroke, causing a loss of horsepower. By me running a pvc, you have to remember that my car is mostly street driven and the pvc will pull vacuum upwards of 3000 rpm before dropping off and by that time the crank evac system kicks in. So I have negative pressure in the crank case all the time which, hopefully, means free horsepower.
I have tried running without over the years and again, I went back to this system because of the "Free Horsepower" aspect. It's working for me and I'm not changing anything at this time. I'm just passing along some personal experience that I've tried and the results.
Re: Summit crankcase evac system: proper way to install? [Re: mshred] #1331457
01/08/13 11:31 AM
01/08/13 11:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Also I did a study on the e-vac at work trying to get
the most vac out of them... I dont put them in the
way Moroso shows... I squash the tube for about the
last 1.5"(makes it narrower but maintains the same area)
and put the end of the tube in the center of the collector
and doing this I got a bit more vac.. and for every
inch of back pressure the exhaust has, it reduces
the vac on the engine by that same amount... till
you get to zero vac and from then on you will start
to pressurize the crank case
NOTE
The end of the e-vac tube is square to the end of
the collector but the end of the tube is 3" past the
end of the primaries
Re: Summit crankcase evac system: proper way to install? [Re: 68LAR] #1331458
01/08/13 01:28 PM
01/08/13 01:28 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Thanks for the info man, I really do appreciate it! I guess I am just trying to decide if I want to ditch the PCV altogether and run the evac on both valve cover's, as I am not sure if there is a benefit to just having the 1 evac tube (or maybe there is, since I guess it is still pulling something, even if only on one side)...I know yours didn't pull vacuum till about 3000rpm, but Crizila said his was pulling from idle (or could that have been the mufflers doing that??)
Did you ever get a chance to pull off the hose and see if you had oil from running the evac on the rear of the valve cover?
Re: Summit crankcase evac system: proper way to install? [Re: MR_P_BODY] #1331459
01/08/13 01:31 PM
01/08/13 01:31 PM
Toronto
mshred Offline
mshred  Offline
Toronto
NOTE
Thanks for the info Mr. P!
With your testing, were you using a straight through muffler and still finding that eventually it would pressurize the crankcase with rpm? I am running Borla XR-1 race mufflers, thinking about switching to bullets, but don't want to have problems either way
Also, where are you guys tapping into and measuring crankcase vacuum from with a gauge?
Re: Summit crankcase evac system: proper way to install? [Re: mshred] #1331460
01/08/13 02:57 PM
01/08/13 02:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was using a adjustable orifice to control the
back pressure... this was on a dyno but back pressure
is back pressure.... I take my vac reading from the
back of the valve cover so its out of the way
Re: Summit crankcase evac system: proper way to install? [Re: MR_P_BODY] #1331461
01/08/13 03:45 PM
01/08/13 03:45 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
No it doesn't. If you *smash* a tube it loses volume. So i would guess the smaller tube was able to pick up velocity.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Summit crankcase evac system: proper way to install? [Re: bigtimeauto] #1331462
01/08/13 03:52 PM
01/08/13 03:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No... you dont squash it flat... you oval it and
it still has the same area... I oval it to help the
exhaust flow past it
Re: Summit crankcase evac system: proper way to install? [Re: MR_P_BODY] #1331463
01/08/13 04:00 PM
01/08/13 04:00 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
No, as soon as you change it from round it loses volume
Re: Summit crankcase evac system: proper way to install? [Re: bigtimeauto] #1331464
01/08/13 04:18 PM
01/08/13 04:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you are right... it looses .01 in area... is
that worth saying
Re: Summit crankcase evac system: proper way to install? [Re: mshred] #1331465
01/08/13 04:53 PM
01/08/13 04:53 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Yes I did and no there wasn't, but I did move the breathers to the front of the valve covers just for GP's.
