Vinyl top molding holes....what to use around clips #1331364
11/06/12 10:42 AM
11/06/12 10:42 AM
PEI Canada
chromedome426 Offline OP
PEI Canada
On a 68 B-body the clips for the vinyl top molding push through holes in the C piller
What do you use to seal around the vinyl top molding clips to keep water out of the trunk?
I am thinking it should be the same stuff thats around the 1/4 panel extention studs, which stays soft almost like play doh. What is the proper name for that stuff and is it still available?
I know seam sealer would work, but might get to hard to get back apart again if need be.
Re: Vinyl top molding holes....what to use around clips [Re: chromedome426] #1331365
11/06/12 10:53 AM
11/06/12 10:53 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I found rubber washers on my original trim clips. I used "strip caulk" around the clips when I put the car back together.
Re: Vinyl top molding holes....what to use around clips [Re: burdar] #1331366
11/06/12 11:49 AM
11/06/12 11:49 AM
PEI Canada
PEI Canada
I did a search on 3M Strip calk http://3mcollision.com/3m-strip-calk-08578-black.html and that is exactly what I was looking for.
Thank you.
