Re: The Right Stuff for oil pan gasket????
[Re: 71birdJ68]
#1330222
11/03/12 09:59 PM
11/03/12 09:59 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Where do you get this stuff. Never heard of it.
any auto parts store should have it.
[Re: bonefish]
#1330223
11/03/12 10:52 PM
11/03/12 10:52 PM
RapidRobert
I ain't used it (yet) but reportedly it's the best there is & it is pricey
[Re: Cab_Burge]
#1330225
11/04/12 06:42 AM
11/04/12 06:42 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
What I have heard about the Right Stuff it is horrible to take apart :That is why I have not used it, yet
thats why i dont use it.ive never had a prob getting things to seal up.if it wont seal there,s a prob that needs to be addressed,not glued.
[Re: Cab_Burge]
#1330226
11/06/12 05:10 PM
11/06/12 05:10 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
You will need explosives to get it apart. But it won't leak.
[Re: fuseable]
#1330227
11/06/12 05:35 PM
11/06/12 05:35 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
I previously used it on the oil pan on my 383 in my Super Bee... You have to use 2 layers due to the windage tray of course. Taking it off was not fun... it took a long long time to take it off... like a couple of hours with the engine on a stand and using a razor blade and a pry bar. It sealed great, but I wont do it again. I damn near had to wreck the pan taking it off.
Paul '69 Super Bee 383 EFI Turbo
[Re: Black_Bee]
#1330228
11/09/12 01:47 PM
11/09/12 01:47 PM
dogdays
I used TRS on an automatic transmission oil pan, it came apart with no drama. It isn't JB Weld, for the love of Pete! I like it because it sets up almost immediately, you can install the part, add fluids and drive. I've done it, no leaks ever.
It does not like gasoline, will turn into foam when the gas hits it. But for everything else it is indeed The Right Stuff. And no, it isn't cheap, but it works.
R.
