The Right Stuff for oil pan gasket???? #1330218
11/03/12 08:20 PM
11/03/12 08:20 PM
Midwest
fuseable Offline OP
fuseable  Offline OP
Midwest
Has anyone used the Right Stuff for a oil pan gasket? I just did a trans filter on my kid's 2002 Jeep Liberty and it had the Right Stuff on it when I removed it so I used the Right Stuff when I put it back on. It was not to difficult to remove the pan, I used a knife to split it and it came right off. I was thinking how good it would seal up on my oil pan with windage tray. Any thoughts pro or con?????????? It sure does a good job of sealing when I have used it. I have always used 2 gaskets and it sealed ok but when I have gotten back into the engine you could tell it was slightly seeping. Just kicking it around, so don't kick me around to much.
Re: The Right Stuff for oil pan gasket???? [Re: fuseable] #1330219
11/03/12 09:04 PM
11/03/12 09:04 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
We used to use it to seal up everything on the 6.5 GM diesels used in HUMMVEEs for the military. We used it in place of valve cover, oil pan and timing cover gaskets. Worked great if you cleaned the surface well and give it proper time to set up. If it will seal up those oil puking, blow-by coughing P.O.S's, You should be fine.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: The Right Stuff for oil pan gasket???? [Re: fuseable] #1330220
11/03/12 09:05 PM
11/03/12 09:05 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Where do you get this stuff. Never heard of it.
Re: The Right Stuff for oil pan gasket???? [Re: fuseable] #1330221
11/03/12 09:06 PM
11/03/12 09:06 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I think some of the newer applications call for rtv only ( no gasket ). But I think it would work ok if you did it like form a gasket where you apply a bead, lightly assemble it then cinch it down after it dries.
Re: The Right Stuff for oil pan gasket???? [Re: 71birdJ68] #1330222
11/03/12 09:59 PM
11/03/12 09:59 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
any auto parts store should have it.
Re: The Right Stuff for oil pan gasket???? [Re: bonefish] #1330223
11/03/12 10:52 PM
11/03/12 10:52 PM
I ain't used it (yet) but reportedly it's the best there is & it is pricey
Re: The Right Stuff for oil pan gasket???? [Re: RapidRobert] #1330224
11/04/12 12:08 AM
11/04/12 12:08 AM
What I have heard about the Right Stuff it is horrible to take apart :That is why I have not used it, yet
Re: The Right Stuff for oil pan gasket???? [Re: Cab_Burge] #1330225
11/04/12 06:42 AM
11/04/12 06:42 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thats why i dont use it.ive never had a prob getting things to seal up.if it wont seal there,s a prob that needs to be addressed,not glued.
Re: The Right Stuff for oil pan gasket???? [Re: Cab_Burge] #1330226
11/06/12 05:10 PM
11/06/12 05:10 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
You will need explosives to get it apart. But it won't leak.
Re: The Right Stuff for oil pan gasket???? [Re: fuseable] #1330227
11/06/12 05:35 PM
11/06/12 05:35 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
I previously used it on the oil pan on my 383 in my Super Bee... You have to use 2 layers due to the windage tray of course.
Taking it off was not fun... it took a long long time to take it off... like a couple of hours with the engine on a stand and using a razor blade and a pry bar.
It sealed great, but I wont do it again. I damn near had to wreck the pan taking it off.
Paul
'69 Super Bee 383 EFI Turbo
Re: The Right Stuff for oil pan gasket???? [Re: Black_Bee] #1330228
11/09/12 01:47 PM
11/09/12 01:47 PM
dogdays Offline
dogdays  Offline
I used TRS on an automatic transmission oil pan, it came apart with no drama. It isn't JB Weld, for the love of Pete!
I like it because it sets up almost immediately, you can install the part, add fluids and drive. I've done it, no leaks ever.
It does not like gasoline, will turn into foam when the gas hits it. But for everything else it is indeed The Right Stuff. And no, it isn't cheap, but it works.
R.
Re: The Right Stuff for oil pan gasket???? [Re: dogdays] #1330229
11/09/12 02:10 PM
11/09/12 02:10 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Only stuff I've used for the past 7 years
