'vert door panels.... NOW WHAT? #1329728
11/01/12 10:49 PM
11/01/12 10:49 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Since Metro didn't come through with the convertible door panels I'm thinking of having Just Dashes reskin them. I've got the wood grain inserts. Will they fit OK with the recovered panels?
Re: 'vert door panels.... NOW WHAT? [Re: 6pkaar] #1329729
11/01/12 11:43 PM
11/01/12 11:43 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
you mean metro wont be making the vert rear panels at all???
Re: 'vert door panels.... NOW WHAT? [Re: domingo] #1329730
11/02/12 05:22 PM
11/02/12 05:22 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Metro has been trying to drum up interest in them before he will spring for the $$$ to tool them up. Only fair, I think. They have been asking prospective buyers how serious they are by having them write down their name, phone number and credit card informtion. Once he gets to some magic number (can't recall if it was 200 sets??)he would notify everyone on the list that he is prepared to move and are they still interested.
That's the last I recall.
I have also pressed them for Challenger door panels without woodgrain holes (seems odd that they put them in in the first place). I think there are a few colors that he has not run either (green, tan).
Re: 'vert door panels.... NOW WHAT? [Re: RP's R/T's] #1329731
11/02/12 05:47 PM
11/02/12 05:47 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
This was posted in the thread reguarding the convert rear panels.
Hello again,
I just received the official word, and we will not be able to produce the convertible panels at this time.
We just could not get enough orders at this time to cover the production and tooling costs.
We will keep this project on the back burner, and revisit it as soon as the market allows.
We gave it a good try guys.
Re: 'vert door panels.... NOW WHAT? [Re: RP's R/T's] #1329732
11/03/12 02:05 PM
11/03/12 02:05 PM
PNW
Beebuzzn Offline
Beebuzzn  Offline
PNW
I second this quote. It would be great if they came without the holes. Easy to put them in, hard to fill.
Re: 'vert door panels.... NOW WHAT? [Re: Beebuzzn] #1329733
11/07/12 06:32 PM
11/07/12 06:32 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
OK, back to my original question, will the woodgrain trim for the 'Cuda door panels fit in the reskinned Just Dashes panels, or does the added material make the channels too narrow?
Re: 'vert door panels.... NOW WHAT? [Re: 6pkaar] #1329734
11/07/12 07:02 PM
11/07/12 07:02 PM
WI
RestoRick Offline
RestoRick  Offline
WI
I had some Challenger panels done many years ago.
They looked very nice, but not original.. you lose the sharp edge definition and the edge flange around the perimeter gets a thicker look.
The vinyl material gives it a very slight cushion to the touch too.
The panel gets a series of tiny holes drilled into it, then the vinyl sheet is attached by vacuuming on the backside of the panel. It comes out wrinkle free.
As for the woodgrain strips fitting, they might.
You could simulate the thickness of the skin with a piece of vinyl and see if there's enough taper to the groove to fit the strip. It would sit up higher in the groove, but it should still fit to the bottom of the new vinyl skin.
I know that doesn't answer your question, but it's some more insight...
Re: 'vert door panels.... NOW WHAT? [Re: RestoRick] #1329735
11/08/12 01:02 AM
11/08/12 01:02 AM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
How thick is the vinyl they cover them with? What would be a good test piece to use to see if they'll fit? Is it close to the seat covering material?
Re: 'vert door panels.... NOW WHAT? [Re: 6pkaar] #1329736
11/08/12 01:06 AM
11/08/12 01:06 AM
WI
RestoRick Offline
RestoRick  Offline
WI
It was a little thinner than the seat material.
If it fits with that you should be good...
Re: 'vert door panels.... NOW WHAT? [Re: RestoRick] #1329737
11/23/12 07:59 PM
11/23/12 07:59 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
dang...and I sold my rear cuda vert panels thinking they were gonna come out with these....
Re: 'vert door panels.... NOW WHAT? [Re: domingo] #1329738
11/23/12 08:13 PM
11/23/12 08:13 PM
New Jersey
FC7 cuda Offline
FC7 cuda  Offline
New Jersey
I did that too
Re: 'vert door panels.... NOW WHAT? [Re: domingo] #1329739
11/23/12 08:32 PM
11/23/12 08:32 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I may need to pull the two sets of spare Challenger vert panels out of the attic & see how they clean up...
Re: 'vert door panels.... NOW WHAT? [Re: 1_WILD_RT] #1329740
11/24/12 04:20 AM
11/24/12 04:20 AM
P
PasiR Offline
PasiR  Offline
P
How about paint them? Is there any good products out there to do that?
