904 low gear set- what vehicles and what parts? #1328085
10/29/12 11:48 AM
10/29/12 11:48 AM
Toronto
mshred Online content OP
mshred  Online Content OP
Toronto
Hey guys,
I would like to do the low gear swap on my 72 year 904 transmission. My transmission currently has aluminum 4 pinion planets front and rear.
My first question- what vehicles have low gear set transmissions? My local wreckers is scarce for 80's year chryslers, so later model stuff like dakota trucks, 6cyl jeeps, late model rams, etc. is all I really have to pick from. What year vehicles would have the transmissions I am looking for?
Second- when I get the transmission apart, what parts am I looking for from it? I have read that the planetaries are steel in these transmissions- can I swap both in to my current 72 year aluminum planet trans? Are there any other mods to get the low gear set to work?
Thanks!
Re: 904 low gear set- what vehicles and what parts? [Re: mshred] #1328086
10/29/12 02:39 PM
10/29/12 02:39 PM
U.P. ,MI.
P
plumcuda Offline
plumcuda  Offline
P
U.P. ,MI.
When I did that swap,I found a 904 from a slant six D100 pickup.
Re: 904 low gear set- what vehicles and what parts? [Re: plumcuda] #1328087
10/29/12 04:07 PM
10/29/12 04:07 PM
Central TX
roe Offline
roe  Offline
Central TX
The guy who built my Trans for me said they come in the jeeps, but didn't specify what years.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: 904 low gear set- what vehicles and what parts? [Re: roe] #1328088
10/29/12 04:27 PM
10/29/12 04:27 PM
Toronto
Toronto
Wondering if the A-500 trans will work for parts as there is one local to me for 100 bucks. Also wondering if the planetaries are steel and if both front and rear will swap into the 904?
Re: 904 low gear set- what vehicles and what parts? [Re: mshred] #1328089
10/29/12 05:20 PM
10/29/12 05:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Any '82 or later trans from the 904 family will have the low gearset.
Re: 904 low gear set- what vehicles and what parts? [Re: mshred] #1328090
10/29/12 06:33 PM
10/29/12 06:33 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
yup
Re: 904 low gear set- what vehicles and what parts? [Re: Dakota_Don] #1328091
10/29/12 08:14 PM
10/29/12 08:14 PM
Toronto
Toronto
yup
Both planetaries are steel? What parts do I need to actually swap in from the A-500 into the older trans to complete the swap?
Re: 904 low gear set- what vehicles and what parts? [Re: mshred] #1328092
10/30/12 01:27 AM
10/30/12 01:27 AM
Toronto
Toronto
I have heard some people mention that some A-500's are not low gear set???
Is there a way to verify from the outside? This is coming out of a 89 dodge D150 2 wheel drive truck if that makes a difference
Re: 904 low gear set- what vehicles and what parts? [Re: John_Kunkel] #1328093
10/30/12 10:45 AM
10/30/12 10:45 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Is it possible to swap and or modify
the low 904 gearset
into the OD unit of a 46RH somehow?
The planetary of the OD unit
is supposed to be
the front planetary of a 727
Spun in 1 divided by 1.45 = 0.69 ratio
1 divided by 1.54 = 0.65
Would be a lower numerical overdrive
I have to rebuild my OD in my 46RH after 190,000 miles so it will be pulled soon anyway.
The AA price for 727 low gearsets is $900 plus.
Re: 904 low gear set- what vehicles and what parts? [Re: 360view] #1328094
11/01/12 09:33 PM
11/01/12 09:33 PM
Toronto
Toronto
I also got to wondering about the front drum and whether or not the A-500's have a 5 clutch front drum and if it can be swapped into the older trans with no issues?
Re: 904 low gear set- what vehicles and what parts? [Re: mshred] #1328095
11/02/12 03:33 PM
11/02/12 03:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All A500's have the low gearset.
Re: 904 low gear set- what vehicles and what parts? [Re: John_Kunkel] #1328096
11/02/12 03:38 PM
11/02/12 03:38 PM
Toronto
Toronto
John, does the A-500 have a 5 clutch front drum that is swapable into earlier 904's? or are there issues with the pump when doing this?
Re: 904 low gear set- what vehicles and what parts? [Re: mshred] #1328097
11/02/12 04:44 PM
11/02/12 04:44 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
you can put 5 disc and steels in a 4 disc clutch pac...
just use the thin .068 disc..and .061 steels..i might have the thickness backwards...but they are the same thickness that the rear drum uses..
you should end up with .050 clearance...i usually have the pressure plate ground .010 to clean it up and get a few thousands extra clearance.
Tony
70 AARCuda Vitamin C
Re: 904 low gear set- what vehicles and what parts? [Re: mshred] #1328098
11/02/12 07:40 PM
11/02/12 07:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
the A500 will have a 5-clutch front drum.
To use the 5-clutch drum in an earlier 904 you need the matching front pump or need to modify the existing front pump.
Re: 904 low gear set- what vehicles and what parts? [Re: John_Kunkel] #1328099
11/02/12 08:18 PM
11/02/12 08:18 PM
Toronto
Toronto
So If I take the front pump from the same A-500 trans, then it should work with no other modifications?
Re: 904 low gear set- what vehicles and what parts? [Re: mshred] #1328100
11/03/12 04:50 PM
11/03/12 04:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It gets a little complicated, if the 904 is pre-'78 you can get in trouble mixing parts; if the 904 is '78 or later non-lockup you can use the later 5-clutch drum and pump but if the 904 is pre-'78 you'll also need the later input shaft and rear clutch piston retainer.
Or the earlier pump can be machined to accept the 5-clutch drum.
Re: 904 low gear set- what vehicles and what parts? [Re: John_Kunkel] #1328101
11/03/12 05:37 PM
11/03/12 05:37 PM
Toronto
Toronto
Are there any threads that explain what has to be machined? Or is it kinda obvious when looking at the parts what would have to happen?
Thanks for the info John
Re: 904 low gear set- what vehicles and what parts? [Re: mshred] #1328102
11/03/12 08:18 PM
11/03/12 08:18 PM
Personally, I wouldn't bother.
I did it a few years back and there really wasn't a difference in a street car.
If you looking for every last hundredth in class racer it may be worth it but otherwise you can save your money and time.
Re: 904 low gear set- what vehicles and what parts? #1328103
11/03/12 09:03 PM
11/03/12 09:03 PM
Central TX
roe Offline
roe  Offline
Central TX
I don't know about that. I just had my 904 rebuilt with a transgo shift kit, low gearset, and a factory high stall converter, and left in my 2.76 rear gears. My car woke up like u wouldn't believe. Much quickening the line, breaks loose my org leg so much easier, even with heavy 22" rims and and a highway rear gear. It could be a combination of everything though.
roe
Re: 904 low gear set- what vehicles and what parts? #1328104
11/04/12 01:29 AM
11/04/12 01:29 AM
Toronto
Toronto
running in a heads up class where im trying to ring every last bit out of the car
