Where to buy Progear 4.30 for Dana 60
#1327083
10/27/12 07:28 PM
10/27/12 07:28 PM
Who sells a ProGear for a Dana 60 ratio is 4.30?
Re: Where to buy Progear 4.30 for Dana 60
#1327084
10/27/12 07:33 PM
10/27/12 07:33 PM
Are Precision Gears any good? 3450 lb.car with 900 HP with a low gear set
#1327085
10/27/12 07:34 PM
10/27/12 07:34 PM
Posts: 437 south central pa
bdaz smblk
south central pa
Strange engineering has them they are 280 bucks.Part number is rp05997430
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: bdaz smblk]
#1327086
10/27/12 08:22 PM
10/27/12 08:22 PM
I think those are prostreet gears. I just broke a set of them.
#1327087
10/27/12 08:37 PM
10/27/12 08:37 PM
Posts: 1,443 central ohio
nss guy
central ohio
Try Victory Performance Parts Dennis Mothershed They are probable the best bet on gears
[Re: Defbob]
#1327092
10/28/12 10:22 AM
10/28/12 10:22 AM
Do you need 4.30's? would 4.10's work for you? Richmond makes a 4.10 pro-gear
Only 4.30 gear 4.10 and 4.56 not an option for my setup.
#1327093
10/28/12 10:28 AM
10/28/12 10:28 AM
Any information on these sets? This might work but not sure if they are strong enough for violent stsrting line launches.Leaving at 4500 on a transbrake is rough on drivelines. http://www.summitracing.com/parts/mgr-d997430
#1327094
10/28/12 10:55 AM
10/28/12 10:55 AM
Posts: 16,930 NC
440Jim
NC
I can't be sure, but I bet those are the same gears made by US Gear and repackaged by Motive Gear. If somebody has bought them, they can compare the ring gear markings to this US/Strange 4.30 pro gear. And I think that symbol after U.S.A. is the US Gear symbol. If they are Richmond Pro Gears, they are clearly marked RICHMOND.
#1327096
10/28/12 11:28 AM
10/28/12 11:28 AM
Posts: 16,930 NC
440Jim
NC
The change from 4.30 to 4.10 could be cancelled by changing the slick dia about 1.5", ie 32" to 30.5" or 33.0" to 31.5", etc. And even changing slick dia half that amount will get you within about 170 rpm.
[Re: 440Jim]
#1327097
10/28/12 12:09 PM
10/28/12 12:09 PM
There must be a reason for the gears to be $75.00 cheaper than the Richmond gear pricing on ProGear sets.$275.00 compared to $350.00 for Richmond gear sets. Another question is do I need the complete installation kit for $129.00 or the less expensive kit for $29.00 for a gear swap. like this one. http://www.summitracing.com/parts/rmg-83-1034-b/overview/
[Re: WheelsUp73]
#1327100
10/28/12 03:48 PM
10/28/12 03:48 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I have a set I bought 7 or 8 years ago from moser
home of the Sox and Martin Hemi Duster
[Re: Gearhead383]
#1327106
10/29/12 11:44 AM
10/29/12 11:44 AM
Posts: 16,930 NC
440Jim
NC
After being on back order for over 2 years, I finally got a set last year from Strange. Turns out I purchased another racecar and never installed them; still brand new in the box. If you are unable to locate a set let me know.
Do the markings on the ring gear look the same as I posted above? Including the little US Gear symbol.
[Re: 440Jim]
#1327108
10/29/12 03:39 PM
10/29/12 03:39 PM
Posts: 276 Mid west
Gearhead383
Mid west
Jim, I will check after work.
[Re: JAKE68]
#1327111
10/29/12 09:55 PM
10/29/12 09:55 PM
Posts: 1,162 s e mich
ro23car
s e mich
what kind of car is this goin in?
What do you care???????LOL
what do you care that i care hahahahha.
[Re: 440Jim]
#1327112
10/29/12 09:57 PM
10/29/12 09:57 PM
I just bought a set of MOTIVE gears from Summit today.I bought the 4.30 ratio.I hope they hold up.
#1327113
10/29/12 10:03 PM
10/29/12 10:03 PM
Posts: 16,930 NC
440Jim
NC
Before you install them, take a picture of the markings so we know what the Italian gears are marked.
[Re: 440Jim]
#1327114
10/29/12 10:35 PM
10/29/12 10:35 PM
I should have them in a few days and will take some pictures for everyone.
