Where to buy Progear 4.30 for Dana 60
#1327083
10/27/12 07:28 PM
10/27/12 07:28 PM
Who sells a ProGear for a Dana 60 ratio is 4.30?
Re: Where to buy Progear 4.30 for Dana 60
#1327084
10/27/12 07:33 PM
10/27/12 07:33 PM
Are Precision Gears any good? 3450 lb.car with 900 HP with a low gear set
#1327085
10/27/12 07:34 PM
10/27/12 07:34 PM
Posts: 437 south central pa
bdaz smblk
south central pa
Strange engineering has them they are 280 bucks.Part number is rp05997430
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: bdaz smblk]
#1327086
10/27/12 08:22 PM
10/27/12 08:22 PM
I think those are prostreet gears. I just broke a set of them.
#1327087
10/27/12 08:37 PM
10/27/12 08:37 PM
Posts: 1,443 central ohio
nss guy
central ohio
Try Victory Performance Parts Dennis Mothershed They are probable the best bet on gears
[Re: Defbob]
#1327092
10/28/12 10:22 AM
10/28/12 10:22 AM
Do you need 4.30's? would 4.10's work for you? Richmond makes a 4.10 pro-gear
Only 4.30 gear 4.10 and 4.56 not an option for my setup.
#1327093
10/28/12 10:28 AM
10/28/12 10:28 AM
Any information on these sets? This might work but not sure if they are strong enough for violent stsrting line launches.Leaving at 4500 on a transbrake is rough on drivelines. http://www.summitracing.com/parts/mgr-d997430
#1327094
10/28/12 10:55 AM
10/28/12 10:55 AM
Posts: 16,930 NC
440Jim
NC
I can't be sure, but I bet those are the same gears made by US Gear and repackaged by Motive Gear. If somebody has bought them, they can compare the ring gear markings to this US/Strange 4.30 pro gear. And I think that symbol after U.S.A. is the US Gear symbol. If they are Richmond Pro Gears, they are clearly marked RICHMOND.
#1327096
10/28/12 11:28 AM
10/28/12 11:28 AM
Posts: 16,930 NC
440Jim
NC
The change from 4.30 to 4.10 could be cancelled by changing the slick dia about 1.5", ie 32" to 30.5" or 33.0" to 31.5", etc. And even changing slick dia half that amount will get you within about 170 rpm.
[Re: 440Jim]
#1327097
10/28/12 12:09 PM
10/28/12 12:09 PM
There must be a reason for the gears to be $75.00 cheaper than the Richmond gear pricing on ProGear sets.$275.00 compared to $350.00 for Richmond gear sets. Another question is do I need the complete installation kit for $129.00 or the less expensive kit for $29.00 for a gear swap. like this one. http://www.summitracing.com/parts/rmg-83-1034-b/overview/
[Re: WheelsUp73]
#1327100
10/28/12 03:48 PM
10/28/12 03:48 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I have a set I bought 7 or 8 years ago from moser
home of the Sox and Martin Hemi Duster
