Heater Box to Cowl Bolt #1325637
10/25/12 12:32 AM
10/25/12 12:32 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Anyone able to post up a few pictures of the correct non A/C heater box bolt (or setup) that attaches the front of the heater box to the underside of the dash?
Couple pix with a scale would be perfect, or if anyone knows where to purchase one that would be helpful too.
Mine wasnt there when I removed the heater box from my current project (1970Cuda if it makes a diff)
Appreciate the help
Re: Heater Box to Cowl Bolt [Re: AAR#2] #1325638
10/25/12 08:15 AM
10/25/12 08:15 AM
indy
70moparmike Offline
70moparmike  Offline
indy
studs go through the firewall and only a strap from the cowl to the heater box on the inside. it is a hook on the passenger side and screwed to the box.
Re: Heater Box to Cowl Bolt [Re: 70moparmike] #1325639
10/25/12 09:25 AM
10/25/12 09:25 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
OK, so a "C" strap with a thread on the end for a bolt
If I can get a picture with a ref scale maybe I can just make one?
Re: Heater Box to Cowl Bolt [Re: AAR#2] #1325640
10/26/12 02:50 PM
10/26/12 02:50 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
I don't have a better pic at the moment but the part has three bends. The base that interfaces at box is flat with a threaded hole to accept a bolt with captivated washer. Washer should be as big as space on box will allow to spread load. There is a bend at base, one mid way up and another at top which makes up the hook that captures the cowl vent opening.
Re: Heater Box to Cowl Bolt [Re: 70mopes] #1325641
10/26/12 05:32 PM
10/26/12 05:32 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
is this the bracket? I copied this pic from an auction - I lost - but this way I would know what to look for - only one I've seen...
Re: Heater Box to Cowl Bolt [Re: shakerjoe] #1325642
10/26/12 05:59 PM
10/26/12 05:59 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Yup - that's the bracket
Re: Heater Box to Cowl Bolt [Re: YYZ] #1325643
10/26/12 11:47 PM
10/26/12 11:47 PM
Connecticut
biginchmotor Offline
Connecticut
I have one that I can send you pictures of if you need them. I can trace the outline of the part also. p.m. me your e mail, John.
Re: Heater Box to Cowl Bolt [Re: shakerjoe] #1325644
10/27/12 10:24 AM
10/27/12 10:24 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thanks to all, was beggining to think I was going to turn up empty pockets on this request.
I think I can just scale it and make one based on the picture.
Re: Heater Box to Cowl Bolt [Re: shakerjoe] #1325645
10/27/12 11:08 PM
10/27/12 11:08 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thanks for posting up that picture, based on it and what I know of the box dimensions I was able to scale and ratio the photo to make a bracket, all I need now is the bolt and washer (scaled and ratioed too)
This baby will work like a champ ! ! !
When I'm finished if you see my car, dont blow the whistle that its not MOPAR original !
Re: Heater Box to Cowl Bolt [Re: AAR#2] #1325646
10/28/12 11:50 AM
10/28/12 11:50 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
I have several of these if anyone is interested.
Re: Heater Box to Cowl Bolt [Re: m46rat] #1325647
10/28/12 01:53 PM
10/28/12 01:53 PM
Connecticut
Connecticut
The bolt on my bracket is a # 10-24 by 3/4 long.
Re: Heater Box to Cowl Bolt [Re: biginchmotor] #1325648
10/28/12 02:36 PM
10/28/12 02:36 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Appreciate the info, confirms what I figured to be good . . . thought I think I actually got .80
Re: Heater Box to Cowl Bolt [Re: biginchmotor] #1325649
10/28/12 02:37 PM
10/28/12 02:37 PM
YYZ Offline
YYZ  Offline
The bolts I have here are:
- black phosphate finish
- 1" long
- 5/16" recessed hex head bolt with 'C' marked on the bolt head
- 9/16" captive washer, free-spinning
Probably 10-24 thread but I haven't double-checked
Re: Heater Box to Cowl Bolt [Re: m46rat] #1325650
11/07/12 09:07 PM
11/07/12 09:07 PM
new york
brotow Offline
brotow  Offline
new york
If you still have the heater "j bolt" I could use one. N.Y 11756
