The BG mighty demon 850 down leg has the same specs as the demon 1000, the 1000 demon with annular boosters is 850 or 825 or 830...
.... the venturi and base plates are the same but the boosters and jetting can be different, I found OTB settings were off for most of our combos but once you dial them in they work fine, for WOT racing you need to fool with the hi speed air bleeds along with the jetting. some of their carbs are full of trash & some are clean
I only tune for WOT so its not too hard to figure out, I can see where a street car with a full fuel curve could be a pain
