wilwoods dragging #1324023
10/21/12 03:34 PM
10/21/12 03:34 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I've just replaced my factory twin pot discs with wilwoods, i bought used. After bleeding them and lining the calipers up, i noticed they're dragging some, i can turn the front wheels by hand with the wheels off but they are reasonably hard to turn.
What could be the problem ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: wilwoods dragging [Re: deaks] #1324024
10/21/12 05:15 PM
10/21/12 05:15 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
mine did that too after i installed new seals. i ended up polishing the pistons on a compound wheel. there were real fine lines on the pistons. after i had the pistons lookin like chrome, they worked fine after that.
Re: wilwoods dragging [Re: deaks] #1324025
10/21/12 05:18 PM
10/21/12 05:18 PM
mi
RATPATROL Offline
RATPATROL  Offline
mi
loosen brake line at caliper see if wheel turns easy, if it does you may have a residual valve in your master cylinder which was used for drum brake applications.
Re: wilwoods dragging [Re: RATPATROL] #1324026
10/21/12 06:01 PM
10/21/12 06:01 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Thanks Rick, do you mean a wheel for buffing paintwork ?
Ratpatrol The car came from the factory with discs, it's a Dart GTS but on second thoughts, it has got a newer master cylinder, steel with the plastic pots on top.
Cheers Mick
best 60ft 1.36
