pinion snubber #1322903
10/19/12 09:24 PM
10/19/12 09:24 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
How far from the floor board should the pinion snubber be on a 66 Charger with a Dana rear?
Re: pinion snubber [Re: 696pack] #1322904
10/19/12 10:51 PM
10/19/12 10:51 PM
NJ
rth Offline
rth  Offline
NJ
It depends on what you're doing with it. For drag racing, no more than 1" to limit axle windup. Plating the hit spot is a good idea. For normal street driving, 2 to 4" depending on susp travel. Super stock springs don't compress much over bumps. Stock springs will compress more, needing more travel distance for snubber.
