Excessive crank case pressure frustration
#1320483
10/14/12 09:58 PM
10/14/12 09:58 PM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
I was using a K&N crank case breather... Nothing internally to baffle oil. Fresh motor build. At idle, everything's ok. Driven in higher RPMs, oil sprays everywhere from that little breather. Huge Mess. Did. This before and the builder went back through it because of oil loss. Not smoking much, just oil getting sucked up into the pcv valve and fed to the intake. So here we are again. My thought is to use a baffled breather (and maybe even a catch can at the pcv valve?) or a crank case evac system like this to manage the blow by: http://chucker54.stores.yahoo.net/morcranevsys.htmlI understand the rings aren't yet seated on this new motor, but this is obviously unusual. If a leak down test shows nothing very telling, am I on the right track for managing the oil.. At least temporarily? The build: 360 stroked to a 408. Eagle crank, H beam rods, forged pistons, aluminum heads, hydraulic roller cam 248/254 duration, 109 separation, roller rockers .600 lift, M1 intake, final compression is 10.5:1 - dyno'd great for the budget at 500hpp/520tq. Just trying to figure out wtf is going on!!
Re: Excessive crank case pressure frustration
[Re: PAINT IT BLACK]
#1320484
10/14/12 10:15 PM
10/14/12 10:15 PM
Is the PCV valve working properly?
I've had one stick before, the engine built up crankcase pressure and blew oil out the dipstick tube!
#1320485
10/14/12 10:18 PM
10/14/12 10:18 PM
moparpollack
Lil Herman
Lil Herman
85086
Are there baffles in the valve covers? What type of driving? Drag race? auto cross?
[Re: moparpollack]
#1320486
10/14/12 10:27 PM
10/14/12 10:27 PM
RapidRobert
I would add some baffles to the valve covers or get baffled ones
[Re: 64Post]
#1320491
10/15/12 03:16 AM
10/15/12 03:16 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Excessive crankcase pressure is only cured by installing new rings. Evidently your rings are not broken in yet or they were improperly installed/broken. Anything you do is only a bandaid for a serious internal problem..
I am truckless..
#1320492
10/15/12 07:49 AM
10/15/12 07:49 AM
Challenger 1
Cincinnati, Ohio
Something is not hooked right if you have a proper baffle in the valve cover. I ran some MT valve covers years ago without baffles and it did this. I bolted a good sized baffle in the valve cover with the PVC valve in it and it fixed my problem. Either that or your motor is junk. Rings should and will seat within minutes of the motor running. Sorry to hear about the rear main...
[Re: 340SHORTY]
#1320493
10/15/12 09:55 AM
10/15/12 09:55 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
Mine is a fresh rebuild and zero oil usage and no perceptable crankcase pressure. I would do a compression/leak down test.
#1320497
10/15/12 04:51 PM
10/15/12 04:51 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Id be looking for a different machinist/builder for the 3rd go around..
I am truckless..
