Took 3 tries to get the correct driver's side window for my 69 Dart.
Here are the first 2 tries; I have no clue what they'll fit. The first one (the one with 2 holes in the bottom) is clear and the only numbers I could find on the glass were AS2 91 DOT21 N55. The bottom measures 29", top edge to the notch is 27.5" and the side with the chrome was 17". The two holes were 1.5" and 15.25" on center from the left edge.
The other window is tinted, and has the numbers AS2 M56 27 on it below the Pentastar. It measures 28" on the bottom, 26" on the top and 16" on the left side and the hole in the bottom was 15.5" from the left edge.
Any help identifying these would be mucho apreciado. Here's a pic of the clear window.
