1970 GTX driveline detailing #1320216
10/14/12 03:05 PM
10/14/12 03:05 PM
Keminmaa
ArcticCuda Offline OP
Keminmaa
Hi all. Looking for tips & pics. Wanna detail my A833 + drive shaft + Dana 60. Inspection marks colours etc needed.
Thanks!
1970 Plymouth GTX 440-6
1970 Plymouth PPR Cuda 489-4
1971 Plymouth Duster Bad Romance 408-W2-8bbl
Re: Driveline detailing [Re: ArcticCuda] #1320217
10/14/12 03:28 PM
10/14/12 03:28 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
1970 B-body?
Re: Driveline detailing [Re: ScottSmith_Harms] #1320218
10/14/12 03:47 PM
10/14/12 03:47 PM
western australia
1cuda Offline
1cuda  Offline
western australia
what did you find when you degreased it?
Re: Driveline detailing [Re: 1cuda] #1320219
10/14/12 03:54 PM
10/14/12 03:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That was a good question because even though some markings were the same, most inspection markings varied from one car to the next even on the same application.
Re: Driveline detailing [Re: ScottSmith_Harms] #1320220
10/14/12 04:03 PM
10/14/12 04:03 PM
Keminmaa
Keminmaa
1970 GTX V-code. I can find three yellow numbers. First one is unclear, second one maybe 7 and last one maybe 6?
Re: Driveline detailing [Re: ArcticCuda] #1320221
10/14/12 04:11 PM
10/14/12 04:11 PM
Keminmaa
Keminmaa
Dana60.
Re: Driveline detailing [Re: ArcticCuda] #1320222
10/14/12 04:18 PM
10/14/12 04:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yours was likely stamped 676 but in yellow paint as opposed to blue (since if you found some numbers remaining in the original yellow paint?). Here's a 69 b-body 18 Spline box with original markings, the tail shaft had been swapped to an A-body piece.
Re: Driveline detailing [Re: ScottSmith_Harms] #1320223
10/14/12 04:34 PM
10/14/12 04:34 PM
western australia
1cuda Offline
1cuda  Offline
western australia
numbers should be 676-don`t know if they were yellow or blue-sometimes other colors too so try to determine what they were. the pic i posted was done recently for a numbers 383 4 speed challenger l/a plant.
all the best
frank.
Re: Driveline detailing [Re: 1cuda] #1320224
10/15/12 10:08 AM
10/15/12 10:08 AM
SE Pa.
LimeliteAero Offline
SE Pa.
the numbers are blue on my 12/69 Lynch Road built 70 B-body.
Re: Driveline detailing [Re: LimeliteAero] #1320225
10/15/12 12:47 PM
10/15/12 12:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW, if adding back the various paint daubs keep in mind that the transmissions were sitting with the input shafts pointed towards the ground and the paint drips ran towards the front of the car. Also, the shade or paint did not fade much if any being under the car most of it's life, try to match any color you find as closely as possible. That green on mine was a true pale/mint green, not a faded version of something else, the yellow "605" is a darker yellow, not bright yellow, etc. The paint was usually a bit thin and was usually a bit transparent once applied, most were applied in rapid fashion and were not perfect and solid like many stamps you see that are added back. Also, the transmission cases were bare cast iron, not painted cast iron gray. If you have your case perfectly clean you can add back the markings and preserve it from rusting while retaining a perfectly original bare cast finish by treating the bare iron with RPM. It works EXTREMELY well at preventing rust from returning.
www.ecsautomotive.com
Re: Driveline detailing [Re: ScottSmith_Harms] #1320226
10/15/12 11:46 PM
10/15/12 11:46 PM
Vancouver, BC, Canada
rtriv Offline
rtriv  Offline
Not sure if you've seen this post but it might have some good info for you
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6494596&an=0&page=192
Re: Driveline detailing [Re: rtriv] #1320227
10/17/12 05:08 AM
10/17/12 05:08 AM
Keminmaa
Keminmaa
No, I have not seen it earlier. Thanks!
This seems to be really tricky. I would say "Mission Impossible" to get everything right. Especially if you are living in the middle of nowhere.
I surrender
Re: Driveline detailing [Re: ArcticCuda] #1320228
10/18/12 07:29 PM
10/18/12 07:29 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Any ideas on font and correct color for the large numbers? 70 RR 383 4sp...no build sheet...and no signs of anything post clean up....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
