brake issue on 98 durango??? #1319593
10/13/12 08:38 AM
10/13/12 08:38 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
On way to work this morn i hit the break pedal and felt it give way and droped doqn closer to the floor
abs and brake lights came on ( stayed on)
pedal does not blead off seams to work like did before but at much closer to floor
thought were.... Wheel cyl or rusty brake line (wouldnt break bleed off?????)
Checked fluid and its bout half way down
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: brake issue on 98 durango??? [Re: toplescuda] #1319594
10/13/12 10:06 AM
10/13/12 10:06 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Sounds like a blown rear brake line.
Re: brake issue on 98 durango??? [Re: Todd] #1319595
10/13/12 01:33 PM
10/13/12 01:33 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Ok so i went out and climbed under it at lunch....
Fluid coming from inside of rear driver drum so guiess got blown wheel cyl.
How much of a pain it gonna be to get drum off????
1971 charger
Re: brake issue on 98 durango??? [Re: toplescuda] #1319596
10/13/12 01:41 PM
10/13/12 01:41 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
if you maintain your brakes and check things out periodically back there, the drum should come right off. if you've never pulled the drums to inspect your brake linings, condition of return springs/hold down hardware, etc. then it may be difficult, but no more difficult than taking the drums off the axle of an older car. if there's a lip, back off the adjuster star wheel with a flat tiped screw driver, and if it's rusted to the axle shaft then hammer on it some, use a little heat, or drain the rear diff and pull the C-clips to pull the whole axle off and beat it off once the axle is removed.
**Photobucket sucks**
Re: brake issue on 98 durango??? [Re: 70Cuda383] #1319597
10/13/12 01:49 PM
10/13/12 01:49 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Had brakes done lil over year ago but if they even pulled back tire off????no clue
1971 charger
Re: brake issue on 98 durango??? [Re: toplescuda] #1319598
10/13/12 01:52 PM
10/13/12 01:52 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If you paid for a brake job, I sure hope they at least pulled the back tires off!! If they didn't, then what kind of a brake job did you pay for?!
Re: brake issue on 98 durango??? [Re: toplescuda] #1319599
10/13/12 01:58 PM
10/13/12 01:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Ever had your brake lines flushed? If not then it's time for both wheel cyls and new fluid.
Our 05 has disc all the way around.
Re: brake issue on 98 durango??? [Re: Challenger 1] #1319600
10/13/12 03:39 PM
10/13/12 03:39 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I dont like doing brake work.......no have never had it flushed
prob right on pulling tires off the back front was done cause put new rotors on
1971 charger
Re: brake issue on 98 durango??? [Re: toplescuda] #1319601
10/13/12 05:52 PM
10/13/12 05:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
Might want to reread what you typed because it makes no sense.
Re: brake issue on 98 durango??? [Re: Challenger 1] #1319602
10/14/12 08:00 AM
10/14/12 08:00 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
It looks stupid lol when i typed it back and front was on two differnt lines and had a big space between them but when post it it shoves every thing togeather
1971 charger
Re: brake issue on 98 durango??? [Re: toplescuda] #1319603
10/14/12 11:33 PM
10/14/12 11:33 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Well after working 12 hour days i got brakes back on tonight
......Took for spin stops better then it has in long time
...but my abs and brake light still on so do they reset or do i still got air or something
...brake fluid was major low by time i got home before doing the brakes
1971 charger
