Re: What type of front seats are you using in your rod?????
[Re: crazyjjk]
#1319409
10/12/12 02:54 PM
10/12/12 02:54 PM
Posts: 26 PA
Waynes48
PA
I installed buckets from a 1995 Pontiac Bonneville in mine. Extremely comfortable seats, and they look good in the car too.
[Re: savoy64]
#1319412
10/12/12 10:49 PM
10/12/12 10:49 PM
Posts: 10,558 Freeport IL USA
poorboy
Freeport IL USA
Depends on the year your rod is, with cars before 37, the front seat area is very narrow. You need a set of buckets that are narrow, and the seats will still touch each other and also touch the door panels. My 35 Dodge sedan had a set of buckets out of an 80s Tempo, they were comfortable and worked well.
When you get to 37 or newer, the width increases and seating options get bigger. My 48 Plymouth coupe has a bench seat out of a Dakota.
Seating in trucks tend to need to be more upright and have short backs. The worst seats I ever put in my 54 Dodge pickup were buckets from a mid 80s 5Th Ave! The seats themselves were great, but the backs laid back too much and were too high to fit under the rear window sill. My knees were almost in the dash, a very uncomfortable ride if longer then a 1/2 hour or so. I replaced those with a set of low back buckets from a swap meet. After removing the head rest, the seat backs fit under the rear window sill and could be slid back, giving me a few inches before my knees would have been against the dash, much better. My 50 got a set of short back buckets from a front drive Mopar (I think they were from an E Class car) with the adjustable backrest. Then I added an ammo box between the seats for storage. With the 48 & newer Dodge trucks, the width of the seat is generally not an issue, the angle of the back rest and the height of the seat back are issues. Buy accordingly. Gene
[Re: poorboy]
#1319413
10/12/12 10:53 PM
10/12/12 10:53 PM
moparpollack
Lil Herman
Lil Herman
85086
Dakota bench it was free but it fits my 39 perfectly.
[Re: crazyjjk]
#1319414
10/13/12 09:28 AM
10/13/12 09:28 AM
Posts: 1,335 Oregon
earlymopar
What poorboy said is true and it also depends on the appearance or style you're after.
For my 37 pickup, I wanted something that appeared as stock as possible and, I didn't want to spend a small fortune getting it. I bought a bench seat frame from the wrecking yard that I removed from a Mazda B2200 pickup ($15). I liked it because had a nice tube steel structure and was close to being usable as it was. Then because of the narrow width and taper of my cab, I cut the seat width and narrowed it, followed by "pinching" it to get the same taper as my cab. It worked out very well and looks great.
[Re: ]
#1319418
10/15/12 12:03 PM
10/15/12 12:03 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I used power seats from a grand cherokee and a console from a durango. They were cheap junkyard finds. The power seats makes getting the right angles easy.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#1319419
10/16/12 02:38 AM
10/16/12 02:38 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
looking for a set of buckets,,not sure if i want a head rest or not for my 40 coupe,,i hate the bucket seat look when they touch each other may as well put a bench seat in it,,,my factory seat isnt to comfortable on longer rides,,,
im thinking late 80s mustang or early 90s T BIRD lots of after market for factory seat covers and color choices,,and they seem to measure perfectly to fit my 40 coupe and have some sort of narrow console
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: poorboy]
#1319421
10/17/12 10:10 PM
10/17/12 10:10 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Pontiac Fiero seats in my '33 coupe.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: 5wndwcpe]
#1319422
10/18/12 09:10 PM
10/18/12 09:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Narrowed the bench from a 79 Newport for my 38 Plymouth, took about 4" out.
[Re: crazyjjk]
#1319428
10/25/12 12:35 AM
10/25/12 12:35 AM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
I was intent on trying a bench seat in my 40. I like the looks of a bench, but I have two extremely comfortable Sebring bucket seats in my motorhom that I will eventually part out, and when measuring... it looks like they are just the right size to LOOK like a bench seat but be more of a "split bench" so each side is adjustable. I'm not sure what to do to be honest. I've got the car in a shop that should be usable in another month at most so I'm gearing up to start doing SOMETHING. I hope anyways...
CrAzYMoPaRGuY
