Every had one of those days #1317534
10/08/12 06:54 PM
10/08/12 06:54 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Putting the engine finally together into the engine bay. I am about to bolt the flex plate to the converter and I forgot that I went with a bigger converter bolt and the flex plate wont fit
I think the engine is coming back out.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Every had one of those days [Re: Kam*Kuda] #1317535
10/08/12 07:13 PM
10/08/12 07:13 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Is the trans that hard to take out ? I would think that would be easy'er ?
Re: Every had one of those days [Re: VernMotor] #1317536
10/08/12 10:12 PM
10/08/12 10:12 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Gonna try but the engine is back an inch so I cant go back to take it out from the dowels
1654.5 Mustang
1955 Land Rover
Re: Every had one of those days [Re: Kam*Kuda] #1317537
10/08/12 10:22 PM
10/08/12 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... just a couple of weeks ago... the wiper linkage
on my Rampage didnt work and I have a 1 piece alum
firewall... I just put the engine and trans in but
I forgot to fix the linkage before the engine went in
but I ended up cutting the firewall to make a access
port with a cover... its not bad looking but you can
see the screws that hold the cover on... no big deal
Re: Every had one of those days [Re: MR_P_BODY] #1317538
10/08/12 11:15 PM
10/08/12 11:15 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
I's all a part of the "game" Rob,i feel your pain. I'd drop the trans and change the flexplate.
Hang in there, it will be all worth it in the end when she's complete. You have any other pulleys?I want to drop some boost.Let me know.
Re: Every had one of those days [Re: Blown 68 R/T] #1317539
10/08/12 11:25 PM
10/08/12 11:25 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Hey Kevin
I just have the 88 crank and 44 on the procharger
The rest are 12 rib pulleys
1654.5 Mustang
1955 Land Rover
