backfire only out drivers side exhuast
#1315337
10/04/12 11:13 PM
10/04/12 11:13 PM
Posts: 3,235 Marion Illinois
72d100
Marion Illinois
Okay guys im at my wits end on this one. the motor is a 400 with a edelbrock dp4b intake. 1406 carb the larger summit cam Camshaft, 1-Bolt, Hydraulic Flat Tappet, Advertised Duration 282/292, Lift .465/.488, Mopar, long tube headers. no clue tube size. parts store wires and coils. champion plugs. i think older electronic ignition box. i have no clue where to start looking .any ideas?
Re: backfire only out drivers side exhuast
[Re: 72d100]
#1315340
10/04/12 11:48 PM
10/04/12 11:48 PM
Posts: 1,100 Fort Lauderdale
Dave440
Fort Lauderdale
Uhhh... misfire? Bad plug? Wire? Cap? One or two wrong (hot) plugs accidentally installed? Carb loading up maybe dripping fuel into intake ports on that side? Usually when I have a backfire on one side its the carb dripping fuel from venturi boosters due to float too high or dirt in needle and seat.
[Re: Jim_Lusk]
#1315345
10/05/12 12:41 AM
10/05/12 12:41 AM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
we just fired up my buddy's challenger, he swore the wires were right, we put it on a lift, took off the driver side from the header, wld go pow after 5seconds, we took down from the lift, i sd lets look again, we had the #5 and #7 crossed.
[Re: cornet684me]
#1315347
10/05/12 07:50 AM
10/05/12 07:50 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
When I bought my car, the owner said it had a stubborn backfire through the carb. Been that way for the 5 years he owned it. I think that's one of the reasons he wanted to get rid of it. #4 and #6 were switched...
[Re: terzmo]
#1315349
10/05/12 09:30 AM
10/05/12 09:30 AM
Posts: 15,487 Florida
scratchnfotraction
what they said. check for vac leaks also. my 440 backfires out the driver side only. but mine is an exhast leak at the rear of the driver exhast manifold. bang all 3 gears at WOT and let all the way off with a snap,then wait a few seconds and bang like a shotgun. then maybe a couple more if I engine break it all the way down form the WOT blast. I did a drive by of my buddys with it in 2nd and reved up, killed the key pump the throttle,hit the key and made everyone on the carport dive for cover. sounds like a SHOTGUN BLAST every time.I have blown muffs apart fliping the key to pop it,but the glass packs are holding up for now. could be the 3x18 echo tips that make the bang loud.
[Re: 72d100]
#1315355
10/06/12 10:37 PM
10/06/12 10:37 PM
RapidRobert
Those plugs are shot. throw in a new set & see if it straightens out. Is that wet oil or dry carbon?
[Re: 72d100]
#1315356
10/06/12 10:38 PM
10/06/12 10:38 PM
72d100
Marion Illinois
So i cleaned the plugs up because they are fairly new. that old Holley just dumped tons of fuel on them. they cleaned up decent enough i put them back in. Then i checked the cap and rotor which was practically new. i did notice some up in down play in the distributor, not sure if that's normal or not? It seemed like when i started it it was running really good and not backfiring. I'm going to play with it a little bit more tomorrow and see
[Re: RapidRobert]
#1315357
10/06/12 10:42 PM
10/06/12 10:42 PM
72d100
Marion Illinois
it was a mix of each. they cleaned up okay so i reused them. im going to put new ones in once i get my first check
[Re: 72d100]
#1315360
10/07/12 12:44 PM
10/07/12 12:44 PM
Posts: 12,812 Tulsa, Oklahoma
Wagonmaster
Tulsa, Oklahoma
I'm probably going to get flamed for this, but, IMHO, get rid of the Champions. I've run Autolite copper plugs in my MOPARS since my first one, back in 1969. No issues with them, ever.
For your application, plug number 85. $1.60 at your friendly Autozone.
[Re: Wagonmaster]
#1315361
10/07/12 12:53 PM
10/07/12 12:53 PM
Posts: 1,650 Harm City Md.
Dan Halen
Harm City Md.
I've used 85s for over 25 yrs, but that carb looks to be fouling the plugs..fix that first. May be float level or rich idle mixture.
[Re: Dan Halen]
#1315362
10/07/12 02:55 PM
10/07/12 02:55 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
plugs look badly oil fouled, take a close look at intake manifold sealing. You could take the carb off and you may be able to detect oil in the plenum.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
