Re: Down on Power
[Re: camastomcat]
#1312219
09/29/12 10:29 AM
09/29/12 10:29 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I would go with more stall like 5800-6000, less timing, like 32*, stock jetting 92's square and start there. Like one guy said, you may need a 456, but I think 8's are in your future with the right tune up.
Carb was used and set up on the dyno as was the timing ......saw it myself .
http://www.youtube.com/watch?v=9rG0doYzstE
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Down on Power
[Re: chryco]
#1312220
09/29/12 10:40 AM
09/29/12 10:40 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Check the ignition timing. Try rolling the wires in the trigger. Go with the way that gives you the most timing.
Your corrected HP is 880. Appears you actual HP on dyno was 817. This could account for the bad MPH. 139 MPH it just aint seeing any HP.
You are not going to set the world on fire with a Powerglide in that car unless you get everything dead on. You need to be in the 7,300 RPM at the finish line. The car should be in the upper 140's to over 150 when everything is good and in good air. I would want more gear probably a 4.88. This will help tremendously. Put some gear in that car and check the dumb stuff and you will be on your way.
Also judging from your dyno numbers. There was 50 HP in the altitude correction. So when you actually run in good air you may need more jet. Bad air less. Best thing is to jet for peak MPH. Don't worry about the other numbers. Go up 2 front and back. If it slows down start going down. Keep going til it runs it's best. Then go up 1 for a little insurance.
Leon
Re: Down on Power
[Re: Leon441]
#1312222
09/29/12 11:13 AM
09/29/12 11:13 AM
Posts: 2,177 ill
dennismopar73
ill
A happy dyno Is a proud dyno!! 800+ hp at the crank = @ 700 @ the wheel! acting like it is down by 150 hp at the wheel!! maybe the brakes are dragging?? or the trans went south what is the trap rpm?? 6800??
410- to- 456s wont do much for ya, a little yes, not no sec tho!!
Re: Down on Power
[Re: Cab_Burge]
#1312229
10/17/12 12:49 AM
10/17/12 12:49 AM
chryco
Winnipeg ,Mb. CA.
Hemiroids like and need more rear gear than wedges do 4.88 or 5.13 in my opinion
I`m startin' to think that way , but I don`t think I`m going to see the gains I`m looking for ....... I still haven`t leak the motor down . That`ll tell the tail I`m sure. Thanks for the suggestions , keep em comin` Chryco
Re: Down on Power
[Re: camastomcat]
#1312230
10/17/12 01:18 AM
10/17/12 01:18 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
I'm in this frame of mind as well.
Converter too tight, not enough gear.
1.39 60's? There are 3300#, 530-560hp, cars going in this range and faster.
Re: Down on Power
[Re: chryco]
#1312232
10/17/12 01:35 AM
10/17/12 01:35 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would do a fuel flow test to see how much time it takes to fill a gal... for some reason your down about 200 hp
Re: Down on Power
[Re: chryco]
#1312236
10/17/12 07:58 AM
10/17/12 07:58 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Have you thought about having it chassis dyno'd ? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: Down on Power
[Re: deaks]
#1312237
10/17/12 09:39 AM
10/17/12 09:39 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Looks like gearing to me. I think you need a minimum of a 4.56 gear, maybe a 4.88 in it. The timing looks fine. Mine runs the best w/ 34-35 degrees in it. I wouldn't touch the converter until you change the gear.
