Re: Broken tranny tailshaft housing question [Re: oldtimer5151] #1312022
09/28/12 07:09 PM
09/28/12 07:09 PM
Utah
dragnduster Offline OP
Utah
I am running a pinion snubber but have it about 3/4" off the floor. I will check the shocks for dents, thanks for the help.
Re: Broken tranny tailshaft housing question [Re: dragnduster] #1312023
09/28/12 07:22 PM
09/28/12 07:22 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You stated that your driveshaft is 3/4" shorter then you would like it. What is that number? At rest I like it to be 3/4" max.
Re: Broken tranny tailshaft housing question [Re: Sport440] #1312024
09/28/12 08:23 PM
09/28/12 08:23 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Went through a phase of breaking these a few years ago. checked driveshaft at the shop that made it...Ok, Changed trans mount from stock to urethane piece, and checked length and pinion angle... broke one. Added an engine limiter and snub bars to the cage... broke one. Had the drive shaft checked for balance and out of round at another shop... said it was "ok", broke another one. Ordered a brand new aluminum shaft from Inland Empire Driveline... never broke a tail again.
It was funny... the change that I made was putting my newly ported heads on and went from running high tens, to low tens/high nines.
Re: Broken tranny tailshaft housing question [Re: dragnduster] #1312025
09/28/12 08:30 PM
09/28/12 08:30 PM
indy
E
eds dart Offline
eds dart  Offline
E
indy
last year on the wednesday test and tune before Monster Mopar. broke on the launch, never knew it. i oiled down the entire length of the track, i couldn,t apologise enough. had made a 4 link change and thought that was the cause, letting yoke bottom in tranny. what happenned is engine limiter mount bolt had nut come loose allowing eng/tranny to move enough to bottom yoke out. i check that nut alot now.
Re: Broken tranny tailshaft housing question [Re: eds dart] #1312026
09/28/12 10:22 PM
09/28/12 10:22 PM
Utah
Utah
Here is a couple of pics. The yoke has about 5" of spline with 3.25" of it engaged on the output shaft and 1.75" hanging off the end of the output shaft with the car at rest with weight on its tires. Do you guys think maybe the shaft is too short? Just to clearify this is a stock low compression 440 short block with a set of 906 heads and Comp magnum 292H cam, 2800rpm convertor and a stock tranny. Thanks again for all your help.
Re: Broken tranny tailshaft housing question [Re: dragnduster] #1312027
09/28/12 10:23 PM
09/28/12 10:23 PM
Utah
Utah
one more with the tail shaft housing slid back into place to show how far the yoke is into the tranny.
Re: Broken tranny tailshaft housing question [Re: dragnduster] #1312028
09/28/12 10:40 PM
09/28/12 10:40 PM
Saskatchewan, Canada
barracudabob Offline
I had the same problem after buying a driveshaft from a reputable shop. Took the shaft to another shop, they said it was out a tiny bit. They fixed it and no more problem.
In your case, I think your shaft is a little too short. you might have to get a new one made up.
Re: Broken tranny tailshaft housing question [Re: dragnduster] #1312029
09/28/12 11:19 PM
09/28/12 11:19 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Pics can be deceiving, but from my view your shaft is to short even with your snub nose seal. I see a angle difference between your shaft and housing, Your rear bushing is probably wore out too, adding to that angle.
Add extra shaft pull out on decell, and I see a good chance for shaft wobble on a performance car such as yours. If thats the case your new shaft may be bent now as well.
With your stock springs and loose clamps, Im sure your having alot of axel rotation, Im not 100% positive, but I think you may of found your gremlins.
Short shaft, worn bushing and loose spring wrap control.
Re: Broken tranny tailshaft housing question [Re: Sport440] #1312030
09/28/12 11:44 PM
09/28/12 11:44 PM
Utah
Utah
Thanks for the input, guess I better get the driveshaft checked out and maybe even a new tube to make it a little longer. How far into the tranny do you want the yoke to go? Should I be using the bolt on spring clamps and keeping the leaves really tight on each other?
Re: Broken tranny tailshaft housing question [Re: dragnduster] #1312031
09/29/12 01:03 AM
09/29/12 01:03 AM
OHIO
THE GLASS MAN Offline
OHIO
You state that you are running a pinion snubber. Pinion snubbers and S/S springs are not to be run together. They will load and unload many times on the track.
Re: Broken tranny tailshaft housing question [Re: THE GLASS MAN] #1312032
09/29/12 12:45 PM
09/29/12 12:45 PM
Utah
Utah
Nope, no S/S springs here just standard A body leaf springs.
Re: Broken tranny tailshaft housing question [Re: dragnduster] #1312033
09/29/12 02:39 PM
09/29/12 02:39 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
The old Direct Connection manual said the correct driveshaft length was determined by measuring from the rear of the tailshaft to the center of the rear end yoke bearing cup minus 3.5"
Re: Broken tranny tailshaft housing question [Re: marvo451] #1312034
09/29/12 03:09 PM
09/29/12 03:09 PM
Utah
Utah
Thank you, that will help me on trying to figure out how short my driveshaft is.
