'71 Plymouth B-Body Front Bumper Question #1311675
09/27/12 09:09 PM
09/27/12 09:09 PM
Maine
shipfitter_sjd Offline OP
Maine
My '71 RR project. Recently installed a rechromed front bumper. The problem is that I cannot get it tight and rigid, like I think it should be.I have tightened all the mounting bolts but it still has fore and aft travel, pivoting from the bottom. In short, the top of the bumper moves and I don't think it should. What did I miss? No mounting bolts for the top of the bumper.
Thanks for the advice.
Steve.
Re: '71 Plymouth B-Body Front Bumper Question [Re: shipfitter_sjd] #1311676
09/27/12 09:16 PM
09/27/12 09:16 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Got a service manual???
(Don't know if it matters or not, but you do know that's a '72 bumper)...
Re: '71 Plymouth B-Body Front Bumper Question [Re: shipfitter_sjd] #1311677
09/27/12 09:23 PM
09/27/12 09:23 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
What did I miss?
a bracket that is very often missing and hard to find..
it is attached to the top of the bumper
with a larger phillips headed screw and it
bolts to the latch tray support under the latch tray.
if you give me a few min,
i will take a pic of what you need and post it
so you know what the animal you are hunting for looks like
there are 2 versions of the bracket and
the bracket was used in 72 also...
Re: '71 Plymouth B-Body Front Bumper Question [Re: RSNOMO] #1311678
09/27/12 09:24 PM
09/27/12 09:24 PM
Maine
Maine
No. I didn't know that was a '72 bumper. Any difference between 71 and 72 that would affect fit, form or function?
Re: '71 Plymouth B-Body Front Bumper Question [Re: flypaper] #1311679
09/27/12 09:27 PM
09/27/12 09:27 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Do you have the mounting brackets that go from the side of the bumper to the fender? The are accessed with the headlight bezels/grill removed. You'll get major movement without them.
Re: '71 Plymouth B-Body Front Bumper Question [Re: flypaper] #1311680
09/27/12 09:29 PM
09/27/12 09:29 PM
Maine
Maine
Flypaper. I didn't see anything on the top of the bumper to attach anything to. Thanks for finding a pic for me to check out!
Re: '71 Plymouth B-Body Front Bumper Question [Re: shipfitter_sjd] #1311681
09/27/12 09:32 PM
09/27/12 09:32 PM
Willow Grove PA
71sat440 Offline
71sat440  Offline
Willow Grove PA
Been a long time but i Think its just the slots for the bumper jack.
Re: '71 Plymouth B-Body Front Bumper Question [Re: pinkduster] #1311682
09/27/12 09:35 PM
09/27/12 09:35 PM
Maine
Maine
pinkduster: The heavy rubber / steel pieces that bolt to the inside front of the front fenders? They are in, but must not be adjusted right / tight?
Re: '71 Plymouth B-Body Front Bumper Question [Re: 71sat440] #1311683
09/27/12 09:39 PM
09/27/12 09:39 PM
Maine
Maine
71sat440: I figured the bumper jack slots were what was being talked about. Not crazy about them. Not a deal breaker for me, but it is a long ways from LA to Maine to swap bumpers again with Bumper Boyz.
Thanks!
Re: '71 Plymouth B-Body Front Bumper Question [Re: 71sat440] #1311684
09/27/12 09:39 PM
09/27/12 09:39 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Those bumpers are complicated! There is the center support mentioned above and then there are the rubber bumpers outside of the headlights.
And yes, that is a '72 bumper. The only real difference in the front bumpers was the jack slot added to the '72s.
Master, again and still
Re: '71 Plymouth B-Body Front Bumper Question [Re: flypaper] #1311685
09/27/12 09:41 PM
09/27/12 09:41 PM
Willow Grove PA
71sat440 Offline
71sat440  Offline
Willow Grove PA
What did I miss?
http://www.ebay.com/itm/1971-PLYMOUTH-RO...dda&vxp=mtr
or
http://www.ebay.com/itm/FRONT-BUMPER-TO-...9ef&vxp=mtr
I'm gathering parts for my can and am in the weeds as far as the grille and bumper mounting myself
Re: '71 Plymouth B-Body Front Bumper Question [Re: shipfitter_sjd] #1311686
09/27/12 09:44 PM
09/27/12 09:44 PM
Willow Grove PA
71sat440 Offline
71sat440  Offline
Willow Grove PA
Thanks!
The only reason I remembered that much is I have a 72 bumper with the slot mig welded up I was going to paint body color back when I was short on cash.
Now I've been rethinking about just getting a rechromed one.
Re: '71 Plymouth B-Body Front Bumper Question [Re: shipfitter_sjd] #1311687
09/27/12 09:55 PM
09/27/12 09:55 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
there should be a hole in the top of the bumper for it
the screw theads into a retainer thats on the bracket
that goes on the opposite side
most cars i have looked at are missing this bracket
yeah, its a stupid detail i look for
when checking out a 71/2 rr..
the curved cut out you see on the bracket
is squared off on the other version.
it was a early/late thing in 71
because both versions have been found on 71 cars
i took a rotted one off my car
and it took a long time to find.
i had wanted ads out for it
here she is....
Re: '71 Plymouth B-Body Front Bumper Question [Re: 71sat440] #1311688
09/27/12 09:56 PM
09/27/12 09:56 PM
Maine
Maine
Thanks for the eBay links. I am goin to have to do some research to find what I am missing and how it goes together. Fun, fun, and more fun!
Thanks again!
Steve
Re: '71 Plymouth B-Body Front Bumper Question [Re: 71sat440] #1311689
09/27/12 10:06 PM
09/27/12 10:06 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
What did I miss?
or
nope! strike 1 and 2..
neither of those is it..
like i said before, it is not easy to find ...
took me a good while.
you can see the retainers on both ends of the bracket
on this other rusty/crusty one..
Re: '71 Plymouth B-Body Front Bumper Question [Re: flypaper] #1311690
09/27/12 11:06 PM
09/27/12 11:06 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
In addition to the center brace that Fly has shown that are also braces on each side going to the fender next to the rubber bumpers. Flat 3" strap with an offset. With the 3 braces the bumper should not move.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: '71 Plymouth B-Body Front Bumper Question [Re: moparmarks] #1311691
09/27/12 11:17 PM
09/27/12 11:17 PM
moparmarks Offline
moparmarks  Offline
Heres a pic of one of the side braces. Mounts with the upper rubber bumper mounting bolt. Actually is 5" long. One each side next to headlight.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: '71 Plymouth B-Body Front Bumper Question [Re: moparmarks] #1311692
09/27/12 11:19 PM
09/27/12 11:19 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
that is where this bracket goes..
opps.. got beat out by mark
Re: '71 Plymouth B-Body Front Bumper Question [Re: flypaper] #1311693
09/27/12 11:20 PM
09/27/12 11:20 PM
moparmarks Offline
moparmarks  Offline
Yeppers. need 2 of them.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: '71 Plymouth B-Body Front Bumper Question [Re: shipfitter_sjd] #1311694
09/28/12 08:02 PM
09/28/12 08:02 PM
Willow Grove PA
71sat440 Offline
71sat440  Offline
Willow Grove PA
Rather then start a new thread since this one seems pretty related, I went through some of my stuff today.
Can anyone tell me if I have a complete set some where in here for both the bumper and grille mounting stuff?
(Other then the 6 main bumper brackets of course of which one of the smaller ones is MIA )
