Need Help! 1973 Interior Paint #1311136
09/26/12 06:06 PM
09/26/12 06:06 PM
Pennsylvania
73bluebird Offline OP
Pennsylvania
I'm currently rebuilding a '73 Road Runner with blue interior. I have all of the dash parts cleaned and ready for paint, problem is that I can't find anyone who has the paint that I want. I have the paint chips from PPG, Martin Senour and Dupont from 1973 and the color original to the dash and steering column is supposed to be a dark blue. After seeing a few cars with this factory dark blue color, I have come to the conclusion that I don't like it (I think it's too dark and looks tacky with the much lighter dash pad and other interior colors). Interestingly enough, the Dupont interior paint chip sheet also shows a Dark Blue Met. chip that the other manufacturers don't list. While this isn't probably the correct original color, it is slightly different and looks a lot better in my opinion. After checking with all 3 paint dealers in town, nobody can seem to cross match this color code. The fact that it is a satin paint also seems to be complicating things for everyone who has tried to research it. I do not have any samples of this paint large enough for a photo match, so I'm pretty much out of luck. Has anyone used this color before or have any idea how I might go about getting a sample to use for matching?
Dark Blue Met.
9834LH
Thanks in advance for any help or suggestions!
Re: Need Help! 1973 Interior Paint [Re: 73bluebird] #1311137
09/26/12 07:53 PM
09/26/12 07:53 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Not sure if this helps at all, but I've used this before on a 1971 GTX dash before with excellent results. DIA 14096 Brite Blue Poly. The only trick for me was to reduce it and spray some test samples and let them dry while noting my air pressure and the distance away that I sprayed. It was the only way to get the perfect factory sheen. If you do exactly as the spec sheet says, it comes out pretty dry and gritty looking. Careful, even, wet coats with low air pressure worked well for me. It does have texture in the paint.
Re: Need Help! 1973 Interior Paint [Re: EL5 71] #1311138
09/26/12 07:55 PM
09/26/12 07:55 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Color
Re: Need Help! 1973 Interior Paint [Re: EL5 71] #1311139
09/26/12 08:00 PM
09/26/12 08:00 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Whoops... Sorry about that Bluebird, just re-read your post and saw that you're looking for the Dark Blue shade. I'm a sloppy night shift worker. lol
Re: Need Help! 1973 Interior Paint [Re: EL5 71] #1311140
09/26/12 11:31 PM
09/26/12 11:31 PM
Pennsylvania
Pennsylvania
No problem, I actually need the bright blue color for some of the other metal interior trim pieces, but I have other codes that I think should work for that. Thanks for the tips on spraying the textured paint, I've never used it before so it's definitely going to be a learning experience.
Re: Need Help! 1973 Interior Paint [Re: 73bluebird] #1311141
09/27/12 01:42 AM
09/27/12 01:42 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
The 'LH' suffix after the Dupont number means it is lacquer. Actually the 'L' is for lacquer and the 'H' is the price code. Anyway, see if they can mix it in 'vinyl paint', which uses vinyl resin instead of balancer and binder. (I think it is enamel based paint, instead of lqcquer.) It can be mixed in low, medium, or high gloss. I'm not sure of this particular color, but I've had it done several times with various colors. And, yes, you can spray the 'vinyl paint' on metal surfaces. The correct gloss will look very original.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Need Help! 1973 Interior Paint [Re: MOBodyman] #1311142
09/27/12 06:58 PM
09/27/12 06:58 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
I painted (dyed) the entire interior , including the metal dash frame of my 73 Dart Sport B3 brite blue using Dupont Master Vinyl Tint . I seem to recall it was around a $100 for the the quart needed . Came out awesome.
Re: Need Help! 1973 Interior Paint [Re: 73bluebird] #1311143
09/27/12 08:29 PM
09/27/12 08:29 PM
PA
Y
yellowfin Offline
yellowfin  Offline
Y
PA
Had some trouble getting my dash paint for a 68 GTX - aztec maroon they called it, and being laquer, was being phased out at the local paint store. They had to check to see if they had the toners for the mix, and I was lucky enough that the only one they didn't have enough of was the flattener. They substituted with some enamel flattener, and it worked well, but said it was the last mix they could do for me with this particular color, as some of the needed toners were just about gone. Price was over $100 for a half pint! I asked if anyone had converted the older formulas to an enamel (read; cheaper and plentiful) base, but was told there was just not enough volume to justify the effort. Best advice I can give would be to find an older paint jobber that still has a good inventory of laquer toners, and go from there.
Re: Need Help! 1973 Interior Paint [Re: yellowfin] #1311144
09/27/12 11:11 PM
09/27/12 11:11 PM
MAIne
MoparABE Offline
MoparABE  Offline
MAIne
your best bet would be to contact mike mancini at instrument specialties. they have the original lacquers available and should be able to mix those codes you need. Tell them John from Maine sent you.
Re: Need Help! 1973 Interior Paint [Re: MoparABE] #1311145
09/28/12 04:26 PM
09/28/12 04:26 PM
Pennsylvania
Pennsylvania
Got some paint ordered from Instrument Specialties. Thanks for the suggestions!
