roadrace w/727 tips.
#1307213
09/20/12 12:32 AM
09/20/12 12:32 AM
Posts: 168 Washington State, USA
Winchester 73
ok so im putting together a 73 dart sport for open track and autocross -not seriose and built cheap.i have a new near stock 383 for my powerplant.i do not know how to turn corners and will be learning.all i keep hearing is to pull out the big block and get less horsepower under the hood but then i hear i need a 5 or 6 speed tranny? so does anyone turn corners with a automatic?pros,cons,dos,donts converter?shifter?coolers?fluid?
Re: roadrace w/727 tips.
[Re: Winchester 73]
#1307216
09/20/12 01:43 PM
09/20/12 01:43 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I havbe a 727a behind my 340six pack in my T/A, and I've been running serious competition solo/autocross (airport/parking lot events, etc,) since the late 70s. With a basic shift-kit, so you can over-ride the automatic and run in your choice of gear selection... all 1st, or 2nd or 3rd, and downshift when you want, the trans is/has been bullet-proof!!! In recent years, I've begun running some hi-speed road course autocross and lapping sessions -- lots of fun at hi-speeds! i have a new trans cooler that fits perfectly from a Dodge Cummins Diesel... maybe a little overkill, but it fits and works... replaced my ~30 yrold B&M small cooler.
NOTE: I do suggest that you DO NOT run a "deep" trans pan, as per my autocross/track experience, the additional volume of fluid only lends itself to run up the dip-stick tube and spill out into the engine bay. I've recntly installed a locking dip-stick assembly... haven't had any problems with spilling fluid. I'd stay with a stock-depth/volume oil pan for the trans. (I have thought of adding some internal fluid baffles inside the trans pan, perhaps with a deeper pan, just to see IF that would have help eliminate the gushing of fluid during extremely hard LEFT-hand manuevers, which would also include deceleration within a LEFT-hand manuever).
I've pulled the 3.91 rear gear out, tried a 3.55, and have now settled for 3.23 for the hi-speed road course events (and easier hwy cruising); typically average 75-80 mph per lap, maxing out 100-115 mph down some of the straights on the different courses... could hit maybe 120-125 ultimate mph at Road America (4-mile course)... the 3.23 is just about perfect for the typical ~2-mile road courses.... you could try a 2.9 or 2.7 rear gear and see if you like those. i like the 3.23 as I run mostly in 2-3 gears on a road course. I currently have BFG 275-60-15s on the rear, but they will likely be replaced soon with 255-50-16s BFG G-Force DOT tires on my race rims 16x10s frt/rr.
I'd like an O/D setup, and maybe someday will do a swap (Keisler 4spd O/D automatic seems the best choice, rather than spend big bucks to convert to a manual 5-spd, such as Keisler/Tremac or Passon's new 5-spd)... I did install a "pistol-grip" automatic shift handle and that is cool!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: dart4forte]
#1307218
09/20/12 04:41 PM
09/20/12 04:41 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I have a '72 360 block I'm not going to be using. Probably a stock bore - think about it. Hmm, also a set of H beam rods. I also have a 360 motorhome engine compleat, 12K , probably a stock rebuild. Still in the '76 motorhome. I firmly believe in a small block for a road course/autocross/handling car. Yes I autocrossed my '98 SS/T truck a few times in '98.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: 72Swinger]
#1307221
09/20/12 11:02 PM
09/20/12 11:02 PM
Winchester 73
Big block A body cars tend to push into corners due to the weight unless you have a serious suspension setup such as coil overs, big sway bars etc. The way I read your post is that you don't have the motor installed as of yet. If that's the case I would consider a 360. You can get a considerable amount of torque equal to that of the big block while enjoying a lighter front end.
A B engine is what 60 lbs more than a 360? So if a guy has a glass hood or front bumper? What about aluminum intake, heads, water pump, radiator etc? Ill give up 60 lbs for the reliability and power of a Mopar Big Block anyday.
at least someones in my corner.i do believe a 360 with a sprinkling of magnum parts and a 904 would hand my 383 it entrails even on a dragstrip much less a roadcourse so i do hear you guys,but the 383 is what i have./6 motor mounts have been cut from the k frame,motor is curently hanging in space awaiting elephant ears.headers are where they need to be and arent hitting anything.too much to list on lbs reduction on this car ,when i get it scaled front and rear you guys are gonna poop yourselves.
great tips on automatics,im gladf i asked cuz one of the first things i was goona do was a deep pan
[Re: Winchester 73]
#1307222
09/20/12 11:08 PM
09/20/12 11:08 PM
amxautox
I'm sure there is a thread on automatics somewhere in the handling forum. I think it was one of the sorta maybe kinda first few dozen threads here. You'd have to go looking for it. Maybe start at the last page and just keep looking going forwards. I know I've read something about autos in road coarses somewhere.
Tom
author unknown
[Re: amxautox]
#1307223
09/24/12 12:00 AM
09/24/12 12:00 AM
Posts: 805 San Francisco Bay Area
MrAngry
Been road coursing my 68 Charger with a 727, reverse valve body and gear vendor unit for 6 years... It's the best set-up I've driven to date and I've drive A LOT of stuff. pm me if you want details.
Never trust a pretty girl... or a lonely midget.
[Re: Winchester 73]
#1307225
09/29/12 02:06 AM
09/29/12 02:06 AM
Posts: 752 AZ - The "dry heat" state
71autoxr
I have a similar set up to Mitch, as well as a similar car. I run my 70 Challenger years of autocross, and several track days with an automatic 727 behind a stock 340. The trans has shift kit mods to it, higher stall converter than stock. I have the stock radiator cooler and and aftermarket cooler in front of the radiator, a deep pan with cooling tubes. I've run with a range of 3:55 to 4:10 gears. I should have a locking trans filler tube...on the "to do" list, as that is one point of contention. Even with the additional steps towards trans cooling the consensus is that I continually ballooned the converter, sending the crank into the thrust bearing, causing no failure, but a significant bottom end rebuild. Crank had a huge groove, and the bearing was toasted. Took some welding, new bearings, and a lot of patience to repair. Car never gave a sign of weakness and it was uncovered during a motor pull when the crank thrust was measured with a yardstick, versus a dial indicator.
Auto trans for non-straight line? Sure. Do I like it? Sure. My car was an automatic before it was my race car, so I made do with what I had. I'm of the opinion that the automatic would do just fine. Just go big on the trans cooling, and oil cooling, and engine cooling, and...you get the idea.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
[Re: autoxcuda]
#1307227
09/29/12 03:35 AM
09/29/12 03:35 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I know on my old Cummins truck the thing had huge cooler lines, like 1/2 from the factory. Definitely an area not to skimp on also.
Mopar to the bone!!!
[Re: 72Swinger]
#1307228
09/29/12 05:57 AM
09/29/12 05:57 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
I had to run reducers. The lines out of my trans are not that big.
[Re: autoxcuda]
#1307229
09/29/12 05:57 PM
09/29/12 05:57 PM
Mopar Mitch
I recently obtained (free!) a brand-new Dodge Cummins trans cooler... so, I measured and made some simple brackets to mount it in front of the radiator... maybe a little overkill, and a touch more weight than I'd care to have up front, but it fits and seems to be functioning a-ok.. still want to have a trans fluid temp gage installed to see what's going on. (My old B&M smaller trans cooler was tossed after I had the trans rebuilt as there was some sediment/metal found in the pan.. after ~25 years of racing, etc.
Mopar Mitch
[Re: 71autoxr]
#1307230
09/29/12 06:02 PM
09/29/12 06:02 PM
Mopar Mitch
One other thing, with the auto trans, if you have increased line pressure, such as from a shift-kit, I'd suggest not really high pressure that the trans bangs into gears at lower rpms... that can cause some instant tire traction loss, espeilally if you're going through a turn/curve, etc... my psi is up but not really high... it shifts smooth and crisp, but not a solid bang as I've driven on other's cars (that's ok for drag racing, but perhaps not so good for road/autxg).
Mopar Mitch
[Re: autoxcuda]
#1307231
09/29/12 06:03 PM
09/29/12 06:03 PM
Mopar Mitch
autoxcuda... nice pic and neat layout!
Mopar Mitch
