Rear Leaf U-bolts too wide, from ESPO? #1306781
09/19/12 08:41 AM
09/19/12 08:41 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi, bought these bolts with the leafs a few months ago and now ready to install. They fit around the axle ok,snug, but I'm not sure if I can bend them in to fit through the bottom bracket. Any Ideas? The originals had a flat area on the inside, I guess bringing the threads closer at the bottom.
Re: Rear Leaf U-bolts too wide, from ESPO? [Re: cudabitten] #1306782
09/19/12 09:18 AM
09/19/12 09:18 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think they go the other way in the brackets. I used there U bolts and they fit fine. No they don't have the flat spots but still worked fine.
Re: Rear Leaf U-bolts too wide, from ESPO? [Re: Challenger 1] #1306783
09/19/12 09:33 AM
09/19/12 09:33 AM
Cincinnati, Ohio
Cincinnati, Ohio
I did not get washers from ESPO, so I got some hardened washers from the local spring place here in town, I'd recomend them. There not on in this picture, they need washers IMO.
Re: Rear Leaf U-bolts too wide, from ESPO? [Re: Challenger 1] #1306784
09/19/12 09:37 AM
09/19/12 09:37 AM
eastern, pa.
eastern, pa.
Ok, it was late last night, I'll check orientation again.
Re: Rear Leaf U-bolts too wide, from ESPO? [Re: cudabitten] #1306785
09/19/12 09:40 AM
09/19/12 09:40 AM
Cincinnati, Ohio
Cincinnati, Ohio
Step away from the computer and go work on the car.
Re: Rear Leaf U-bolts too wide, from ESPO? [Re: cudabitten] #1306786
09/19/12 03:40 PM
09/19/12 03:40 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
yes, you have them lined up wrong.
Re: Rear Leaf U-bolts too wide, from ESPO? [Re: cudabitten] #1306787
09/19/12 04:02 PM
09/19/12 04:02 PM
Cincinnati, Ohio
Cincinnati, Ohio
Same car, 6 years later.
