Re: ROCKER SHAFT TORQUE VALUES???
[Re: Labratt]
#1306431
09/18/12 03:05 PM
09/18/12 03:05 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
BB I'm assuming? A 3/8 grade 8 bolt can take 35 lbs/ft. If it's just a standard grade 5 then 25 is enough.
[Re: Labratt]
#1306437
09/18/12 05:36 PM
09/18/12 05:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Randy, check the ball adjuster at the PR to make sure they arent touching at full lift.. cant see with the grease on it
