Got a tip from here and it worked awesome
#1306068
09/18/12 12:11 AM
09/18/12 12:11 AM
Posts: 5,796 minnarusta
TX9H6E4CUDA
minnarusta
I was always having problems with painting bolts and when I went to install them they would look terrible. Well I got a tip from the painted bolt thread earlier to get a toaster oven and heat them up. Well I tried it tonight with a thrift store unit and it worked awesome. Within ten minutes they were dry and had a durable finish. Thanks for the awesome tip Now I just gotta find a set of strut rod bolts for the lower control arm as they seemed to grown legs and dissapeared.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Got a tip from here and it worked awesome
[Re: autoxcuda]
#1306070
09/18/12 02:33 AM
09/18/12 02:33 AM
Posts: 6,583 SE Pa.
LimeliteAero
SE Pa.
Baking any painted part really increases it's durability and resistance to fisheye too.
Fish eys happen during painting due to contamination on the surface. How does baking eliminate that from happening?
[Re: LimeliteAero]
#1306071
09/18/12 03:28 AM
09/18/12 03:28 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
We were painting a fan with cruddy Krylon spray paint. We sprayed the bead blasted part with laquer thinner, it quickly dried and then it was painted. Had fish eye type areas.
If it were better paint, it would not have been an issue. The more expensive hard to find Industrial Krylon doesn't seem to have those issues.
I cleaned the paint off. Put the fan in my oven. Painted with cheap Krylon. And no issues. And I can run my fingernail across the paint without scratching it. Can't do that with non baked same paint. The heat just seems to promote adhesion. Doesn't run as easy too.
[Re: autoxcuda]
#1306072
09/18/12 03:29 PM
09/18/12 03:29 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Even after blasting if you preheat the parts it burns the contaminates out of the pores.
NS1AAR
[Re: ns1aar]
#1306074
09/18/12 04:08 PM
09/18/12 04:08 PM
autoxcuda
So Cal
That makes since.
So should you heat the parts for a while to get the contaminates all out? Last time I just put them in long enough to get the part hot; Like 5 minutes.
Just seem the cheap Kylon type paints do not go on very good anymore. Very fustrating.
[Re: autoxcuda]
#1306075
09/18/12 06:27 PM
09/18/12 06:27 PM
ns1aar
ontario calif
Here at the bomber factory we heat parts and let them cool before gluing things to them gets the oil and silicone out
NS1AAR
