date codes mini spare
#1305581
09/17/12 12:05 PM
09/17/12 12:05 PM
Posts: 4,920 new berlin wisconsin
Mr T2U
i have a mini spare i need help with reading date codes.
by the valve stem there is a small 9 then some space then a 11 in larger sized front. on the other side is 14 then 5.5. i would assume this means 14" rim and 5.5" wide. then in the lig circle there is a 11 in the same size front as by the stem. then between the the next lug there is a k2 then a 9 directly under the k2.
i am at work so i can't post a pic until i get home ferom work.
perception is 90% of reality
Re: date codes mini spare
[Re: YYZ]
#1305584
09/18/12 08:54 PM
09/18/12 08:54 PM
Mr T2U
thanks for the info.
here is a pic of the rim. my next question is what car is it for?
if i remember correctly i removed it from a ebody in the mid 70's. it had a regular tire mounted on it when i removed it from a totaled car.
