318 Dual exhaust #1305076
09/16/12 09:36 PM
09/16/12 09:36 PM
Long Island, New York
57Fury440 Offline OP
Does anyone know if there is a dual exhaust kit available for a 1972 Barracuda with the 318. It has the stock cast iron manifolds which I would like to keep. This is a street only car and I'd like to keep it fairly quiet.I could most likely use the pipes and mufflers from the single exhaust system on both sides but I would need pipes to connect them to the exhaust manifolds.I'm sure a good muffler shop could do this but I thought there might be a kit out there. Thanks
Re: 318 Dual exhaust [Re: 57Fury440] #1305077
09/16/12 09:43 PM
09/16/12 09:43 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
You'll most likely be adapting a 340 system to your manifolds, it's
probably better to take it to a good muffler shop and have them
bend a set for you.
Re: 318 Dual exhaust [Re: Dan Halen] #1305078
09/17/12 06:59 AM
09/17/12 06:59 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I purchased a dual exhaust system from Summit and adapted the factory y-pipe, was fairly easy to do if you have a welder.
For what they charge around here for a "custom bent system", you can buy a cheap welder and the dual exhaust kit and still have money left over.
Local here in New England you are looking at $500 for a dual system with crappy pipes that will rot out in a year or two, junk mufflers and bad crimpy bends.
Re: 318 Dual exhaust [Re: 57Fury440] #1305079
09/17/12 12:03 PM
09/17/12 12:03 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Accurate exhaust makes 318 dual exhaust kits. I bought one for my Challenger. They'll ask you for the manifold part #s when you order. You can get the systems with or without resonators.
Re: 318 Dual exhaust [Re: burdar] #1305080
09/17/12 02:42 PM
09/17/12 02:42 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Jegs has some pretty nice systems for the money. I used their A-body on on my M-body Gran Fury. Here is their system for your car. I am sure you could get the down pipes from any local shop.
http://www.jegs.com/i/JEGS-Performance-Products/555/30504/10002/-1
Facts are stubborn things.
