Getting the toe in right? #1304892
09/16/12 05:53 PM
09/16/12 05:53 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I'm wondering what ET difference setting the toe in to 0 at 1 inch rise will yield if I'm at max factory(toe in) specs now. Any experiences with this?
Yeah, it's got a smallblock.
Re: Getting the toe in right? [Re: 340B5] #1304893
09/16/12 06:28 PM
09/16/12 06:28 PM
ill
dennismopar73 Offline
ill
Not much if any!! You would have to test on nearly the same type weather day!
But if you fine tuning the car for ultimate gain that is an area to look at , hundreths couple at best !
more than that, the car was out worse than you think! JMO!
Re: Getting the toe in right? [Re: 340B5] #1304894
09/16/12 06:58 PM
09/16/12 06:58 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The mopar chassis manual says to align the front end with it raised 1", the amount of toe change depends on tie rod slope and bump steer, if your steering box/pitman and idler are in the correct position, then the bumpsteer is negligible and wont affect toe at all..... Tim
