mock up ??? for you guys #1302500
09/12/12 12:01 AM
09/12/12 12:01 AM
nc
E
earthmover Offline OP
E
nc
trying to make sure all is well in the drive train to rearend.. i dont have a center section right now to use how do i go about making sure everything is in line as it should be??? would a string line or lazer level work for this??? or do i need to get the center ??trying to mock things up so i can pull it all apart and paint the chassis and put it all back tog..
Re: mock up ??? for you guys [Re: earthmover] #1302501
09/12/12 12:15 AM
09/12/12 12:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Is that a 9" or 8 3/4... they make a plate that bolts
on that shows you the centerline of the pinion...
I got my 9" one from S&W but other places sell them.
I made a tool that mounts in the #5 main with a laser
that I trued in the lathe... I point the engine right
at the pinion... then later you can dial in the pinion
angle
Re: mock up ??? for you guys [Re: MR_P_BODY] #1302502
09/12/12 12:19 AM
09/12/12 12:19 AM
nc
E
E
nc
9" i will look for that plate remember what the cost was??? also what center are you running? strange , moser, steel, alum???i hear guys say run the alum. since your going light weight, but im not to sure of how they will last..my buddy has 1 in his stratus but he dont have alot of passes on it..
Re: mock up ??? for you guys [Re: earthmover] #1302503
09/12/12 12:24 AM
09/12/12 12:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The plate is about $20(sort of a rip off) but if
you need it, you need it..... and you do plus it
makes it alot easier... I just use the bronco carrier
(which has 1 more rib in it) and the better support...
plus you want/need a back brace
Re: mock up ??? for you guys [Re: MR_P_BODY] #1302504
09/12/12 12:28 AM
09/12/12 12:28 AM
nc
E
E
nc
thanks mr.p ..that rear my be something to look in to...this 1 has the brace on it already as well...any thoughts on the alum. over the steel or vice versa???
Re: mock up ??? for you guys [Re: MR_P_BODY] #1302505
09/12/12 12:31 AM
09/12/12 12:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is a pic from the back of my 9"... with the back
brace and the lower bar is to stiffen up the lower
shock mounts from side movement
Re: mock up ??? for you guys [Re: earthmover] #1302506
09/12/12 12:37 AM
09/12/12 12:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The alum one is plenty strong enough... what do you
figure the TOTAL weight to be(on the track)... the
steel/iron one is alot cheaper but heavier
Re: mock up ??? for you guys [Re: MR_P_BODY] #1302507
09/12/12 12:41 AM
09/12/12 12:41 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
angle
ART has this one
http://www.appliedracing.com/rear-end---housings-and-components/images/019973_LG.jpg
Re: mock up ??? for you guys [Re: MR_P_BODY] #1302508
09/12/12 12:47 AM
09/12/12 12:47 AM
nc
E
E
nc
i hope to be under 2600lbs race ready..
73 duster full 2/3 chassis with ladder bars, full cage, glass front end and doors, truck will prob. be glass, back bumper prob. be glass as i have 1 already,400 low deck with alum. heads and a 727. skinny fronts and 31/18.5 backs right now..all wilwood brakes, alum. inter gonna use lexan in all windows.. strut front end with rack
Re: mock up ??? for you guys [Re: earthmover] #1302509
09/12/12 01:07 AM
09/12/12 01:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The alum center will work fine... if you want to pay
the price.... the plate for the diff from S&W is
95-019 for 19.95... it nice .. shows the axle C/L
as well as the pinion C/L with a slot cut in it for
a tape measure to hook in... I tried to get it on their
web site but it doesnt show it(their web site sorta
sucks) so you would need to call and get their catalog
610-498-7303..... or 800-523-3353.... they have a
bunch of brackets and tabs you might need also...
pretty decent on price also... I buy all my brackets
and stuff like that from them(cheaper than me making them)
Re: mock up ??? for you guys [Re: MR_P_BODY] #1302510
09/17/12 03:01 PM
09/17/12 03:01 PM
nc
E
E
nc
didnt want to start a new tread so i will put the updates in this post.. i got a little work done to the car ..got the dash fitted ..alot of in and out cut here cut there.. but its in and fit nice..gonna paint it up when i start painting the cage and rails..will post pics tomm. they are still in the shop on the card..
