Re: Accelerator pump shot
[Re: General 68]
#1302246
09/12/12 07:21 PM
09/12/12 07:21 PM
Posts: 3,877 Oregon
hooziewhatsit
At WOT, the top of the plunger should be flush with the top edge of the carb body. If not, the pump could potentially be higher than the fuel and not push anything but air for the first bit of travel. Tweak the bendable arm to correct this.
Also, if the floats are too low the top of the pump could also be out of the fuel.
[Re: RapidRobert]
#1302248
09/20/12 11:12 AM
09/20/12 11:12 AM
Posts: 401 Norway
General 68
Norway
Update: I put in a new accelerator pump plunger and the small delay is the same. Raised the float level a little and adjusted the pump rod and drove the car till it was fully warm. Tested idle to wot and it bogged. Then I had to take care of a few other things so the car sat for 30 minutes. Took it out again and after making sure the choke was fully open I smashed the pedal a few times without getting a bog! Throttle respons was crisp and clean! Tried som more an all was fine. Took the car for a drive and after about 5 minutes of driving i tried cracking the throttle wide open again and it bogs Seems like something in the ignition circuit is not up to the task. I'll start with the ballast and eventually follow up with ecu and coil as I have spares. Briefly explained the car will bog when it has been driven for a while. After cooling down for 30 minutes it does not bog. Drive some and it bogs again. I'll see if I get some time to dig into this tonight. Please let me know if you see things I haven't thought about. (Ampere meter is by-passed and wiring checks out good to ballast.
[Re: General 68]
#1302249
09/21/12 06:55 AM
09/21/12 06:55 AM
Posts: 277 Cincinnati, Ohio
chargincharles
Cincinnati, Ohio
Just to eliminate the possibilities- You say it ran fine and then developed this problem... Have they switched to a higher ethanol-blend of gas? Like an E-15 or greater? AVS's don't like the alcohol gas as the aluminum bodies tend to transmit heat faster and therefore evaporate the fuel quicker... Next question- Are you running a carb spacer/heat shield? All my AVS's I run with a some kind of phenolic spacer or with a heat shield for the reasons stated above... Also- on an AVS the fuel should come out of the squirter IMMEDIATELY- there should be NO delay. I would check the pump squirter for a blockage of some kind that would be creating the delay- or the adjustment of the linkage rod that controls the travel of the pump. You may just have a linkage that is loose, worn or bent.
And- if it's ignition- Check your ignition box- they can go bad over time. I had an Orange Box that croaked after 3 years on the car- it looked just fine, but one day I'm going up the road and -zap- engine shuts off like I turned the key. Swapped a new box on and drove off.....
Finally- The AP diaphram needs time submerged in fuel/oil to swell and fit the bore of the pump chamber. With a leather diaphram, I would soak it in oil overnight before installing it. With the rubber version that currently is used, I'd probably do the same thing, but I don't like the rubber ones.
Good Luck, CC
[Re: General 68]
#1302251
09/22/12 12:07 AM
09/22/12 12:07 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I'm not sure about your ignition
but on the carb, i would look closely at the checkball under the squirter sealing. that check ball is there to hold fuel near the squirter, if there is any gunk buildup, it may be bleading down.
another thought is when the engine gets hot, todays fuel boils very easily, while your driving, boiling gas may be pushed out the squirters and you don't know it then when you mash the pedal there is no gas sitting above the check ball
another thought, is the weather may have turned cooler and the carb seems leaner to the engine and you may need to open the A/F screws a bit.
If you have the balls to take drill bits to the carb, PM me and I will tell you how to take care of the bog forever
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 540DUSTER]
#1302254
09/24/12 06:17 PM
09/24/12 06:17 PM
Posts: 401 Norway
General 68
Norway
Yes the pump plunger is flush with the carb body at wot. It was a little high but adjusting it did not make any difference.
Ignition opdate: After swapping out the FBO coil for a known good old coil the car runs smoother than ever. The two FBO coils I have around measure the same impedance and the same voltage drop after ballast resistor. 12V in measures 5,5V at coil. Ballast came with the FBO kit and is marked 0.8 ohms. With the known good coil in the circuit I get 9V at coil. So are the FBO coils both bad or can't the ballast take the load they create or should the ballast for the FBO coils simply have less resistance? These are questions I would like to shine a light on!
The coil swap worked wonders but the engine still bogs. Here is a summary from tonights test runs: Warmed the enging - smash the throttle several times an it bogs every time. Stop the engine and do some tweaking, start up an NO BOG! Drive a minute, smash it an IT BOGS. Actually it will always bog after being driven, but after a short stop or just idling for a minute the throttle can be smashed many times in a row without making the engine bog.
Hmm.. fuel boiling ? Weather is rather chilly here now and I believe the fuel actually should be cooler when driving than after the engine has been shut off for a minute. The engine starts really easy after being shut off for a while. Floats too low? I set them at factory settings but raised them some last time i thinkered with the car. Not sure what to try next. I do have a 1/2 inch phenolic carb spacer I could try but the air filter box won't allow the hood to be closed. Ideas?
[Re: General 68]
#1302255
09/24/12 06:38 PM
09/24/12 06:38 PM
RapidRobert
With the new plunger do you get immediate tip in? and repeatedly pulling the throttle gets the same immediate tip in? this is with eng off & visual down the throat. I would put 2 strips of clean rag past the nozzles to catch the raw gas to do this check. On a seperate note the 2 FBO coils show 5.5V and the "known good coil" shows 9V using the same ballast? What's the ohms (pri/sec) difference between the FBO coils and the known good coil? EDIT I'm thinking there's a fuel starvation issue of some sort. worn pushrod (BB)/partly plugged sock/pinhole in gas line/partly plugged filter/internal carb issue. Keep on it
[Re: RapidRobert]
#1302256
09/24/12 06:56 PM
09/24/12 06:56 PM
Posts: 401 Norway
General 68
Norway
Always a strong steady shot but the throttle blades move a little before the nozzles squirt. The new pump diaphragm did not change anything. Even when I move the throttle lever fast this small distance it will not squirt. I assume the fuel should come out the nozzles as soon as the lever is moved? On the other hand the throttle responce is good as long as I don't floor it completely. The engine takes a 2/3 throttle smash but not more without hesitation.
I have not measured the good coil but I'll do that tomorrow just to see what we have here. Same ballast for all readings.
Another idea: is it possible that something is leaking inside the carb when the throttle is held open some, as when driving, and the engine then needs some time to clear up? This will mean that I have a rich bog. The fact that the bog is gone after the engine has been shut off for a minute really puzzles me.
I run an electric fuel pump with 1/2" fuel- and return lines and dual 3/8 lines from regulator to carb. Fuel pressure is currantly 4,5 PSI, maybe a tad on the low side but I can not see that this should create this problem. The car pulls strong up the RPM's.
[Re: General 68]
#1302257
09/24/12 07:03 PM
09/24/12 07:03 PM
RapidRobert
ANY chance you could borrow another known good carb for a day to see if you could pin it down to the carb or to the fuel delivery? Got an idea, might take off the squirter & see if the check valve underneath is free & might spray it all out and the nozzle with starting fluid,could be a piece of debris
[Re: General 68]
#1302259
09/25/12 03:11 AM
09/25/12 03:11 AM
Posts: 531 USA
540DUSTER
USA
If the engine is bogging when you smash the pedal,it could be that the opening rate of the secondaries needs to be adjusted.I am not sure about the new thunder carbs,but there should be a spring on the air door you can adjust.Try to tighten the spring and see what happens.
[Re: 540DUSTER]
#1302260
09/25/12 02:24 PM
09/25/12 02:24 PM
Posts: 401 Norway
General 68
Norway
I have played with the air door and it seems like I can tune out a bog by tightening it a bit more than two turns from closed, but then the secondaryie won't kick in. Best result the other way is around 1,4 turns after closed. I sure can try it even lighter but I can not see how this should affect the fact that the bog goes away if I stop the engine and restart after a couple of minutes. After warmed up the engine will bog from idle but if stopped for a short time and restarted the throttle responce is crisp and clean. Drive it a mile an the bog is back. Even letting it idle for a minute seems to take away most of the bog. Can this be a choke problem? Just thinking. The choke pull-off is adjusted to specs and I have tried different settings for the spring tension. The car starts really easy but runs a little rough until the choke is open wich with the currant setting happends after about two minutes. I sure can wind up the choke spring to delay the choke some but it will still run rough.
