SB tension & chain ???? #1300977
09/10/12 09:41 AM
09/10/12 09:41 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
What type of chain do you use?
I hear a stock one because the other's eat the tensioner.
Thanks Matt
Re: SB tension & chain ???? [Re: MattW] #1300978
09/10/12 10:10 AM
09/10/12 10:10 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I used a double roller and had no issue with eating the tensioner, I packed the chain with grease before startup, after 20 dyno pulls there was no sign of wear at all.
Re: SB tension & chain ???? [Re: MattW] #1300979
09/10/12 10:55 AM
09/10/12 10:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Double roller here also... its been on the road and
on a short bit of dyno... looked like new... I just
got done going through it again and its going back
to the dyno tomorrow for more dyno time
Re: SB tension & chain ???? [Re: MR_P_BODY] #1300980
09/10/12 11:18 AM
09/10/12 11:18 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Just finished rebuilding my motor. It had just short of 200 passes on it. I lost a couple of lobes on the cam. I was using a tensioner on mine as well. My cam bearings were worn out on the bottom side. My VS were orginally setup with 180 lbs on the seat and 380 lbs open. I don't feel like that should have caused the wear we saw. I didn't put a tensioner on it this time. Jim
Re: SB tension & chain ???? [Re: rt66jim] #1300981
09/10/12 11:35 AM
09/10/12 11:35 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Thanks for the info guys.
