CLAY SMITH FUEL PUMP #1299626
09/08/12 02:02 AM
09/08/12 02:02 AM
MS
ACIDHEAD Offline OP
ACIDHEAD  Offline OP
MS
I HAVE A CLAY SMITH MECHANICAL PUMP FOR A SMALL BLOCK I AM THINKING ABOUT PUTTING ON , HOWEVER THERE IS A CAST IRON NIPPLE STICKING OUT ON THE RIGHT SIDE OF THE CYLINDER BLOCK THAT IS INTERFEREING WITH THE FUEL PUMP CAN IT BE CUT OFF AND ALSO THE RADIATOR HOSE IS RUBBING ON THE PUMP. ANY ADVICE GUYS?
Re: CLAY SMITH FUEL PUMP [Re: ACIDHEAD] #1299627
09/08/12 12:53 PM
09/08/12 12:53 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
To use that pump you will have to cut off the block protusion (won't hurt a thing) as well as modify the water pump neck by cutting it off and moving it slightly and rewelding it.
Re: CLAY SMITH FUEL PUMP [Re: Dartcuda] #1299628
09/10/12 11:36 AM
09/10/12 11:36 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Or put a 69 water pump on it. This moves the WP inlet to the other side of the crank.
