Page 2 of 5 1 2 3 4 5
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299439
09/08/12 02:50 PM
09/08/12 02:50 PM
SoCal
Brian Hafliger Offline
SoCal
555Hp and 530Tq.
I sincerely hope you're wrong! J.Rob
Lets just say that I'm sure the potential to get close to 600Hp is there...I guess it depends on the dyno to. On our dyno I would expect 555 or so. On a Superflow I'd think maybe 575...Stuska I'd expect 600!
Brian Hafliger
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Brian Hafliger] #1299440
09/08/12 06:36 PM
09/08/12 06:36 PM
BPE Offline
BPE  Offline
I will say 583 hp and 552 tq. But whatever the numbers are I hope it does what you want in the car.
Rod
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299441
09/08/12 07:54 PM
09/08/12 07:54 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
its gonna be stout either way...best of luck and have fun
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Brian Hafliger] #1299442
09/08/12 08:29 PM
09/08/12 08:29 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
555Hp and 530Tq.
Alot of people argue over happy dynos low dynos and lets not forget the infamous track.
I would like to know. If a car is not sorted out properly does the MPH dictate what ET you would be able to run with a good car? Does the MPH stay constant (to a degree) even if the ET is lacking??
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: MattW] #1299443
09/08/12 09:11 PM
09/08/12 09:11 PM
SoCal
SoCal
We race CARS, so it only makes sense, to me anyway, that the car needs to be as good as the engine, trans, etc...
So if you don't pay alot of attention to things that help mph like front end alignment, tires, pressure, oil viscosity, brake drag, and such your not going to get all you can. It's easy to say on the net that your cars mph is xxx but what it takes to achieve that is probably not so easy.
Truth is different dyno brands will show different #'s...hell same brand dyno's can show different #'s depending on so many things. Just like flow benches. In the end, what the car runs is also dependant on many many things.
I see alot of customers that want a certain mph or e.t. but may not be willing to work on the car until they get it...if they buy an engine they figure it's the engine builders responsibility to make their car meet their expectations.
Brian Hafliger
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: MattW] #1299444
09/08/12 09:30 PM
09/08/12 09:30 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I think you are a little short on duration and/or compression to get any more than around 550 lbs-ft If you have valve springs that will let you keep things stable to a high enough rpm,you might get a little over 600 hp.
Might take a higher rpm than you can get with a stiffly sprung hydraulic though
Keith
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Dunnuck Racing] #1299445
09/09/12 08:32 PM
09/09/12 08:32 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Heres my 580 HP and 560 TQ.
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299446
09/09/12 09:21 PM
09/09/12 09:21 PM
SoCal
SoCal
555Hp and 530Tq.
It wouldn't be the FIRST time!!
Brian Hafliger
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: MattW] #1299447
09/10/12 08:32 AM
09/10/12 08:32 AM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Matt, you and Dunnuck racing are right in line with what I think.
I should have it together and on the pump by this weekend. This is my 2012 EMC entry, It is NOT a real serious effort-that will be for next year. IF the world doesn't explode or something--hahaha. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299448
09/10/12 09:08 AM
09/10/12 09:08 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I think I would like to help you out if it not a big block.
We be in touch with you soon. Matt
BTW nice job on the EQ heads. You should digitized the Port get that boat anchor working. LOL
Nice to see some serious effort with non exotic parts.
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: MattW] #1299449
09/10/12 06:55 PM
09/10/12 06:55 PM
Toronto
mshred Offline
mshred  Offline
Toronto
what kind of rpms do you think this engine is going to turn? or what are you feeling is safe with that hydraulic roller?
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: mshred] #1299450
09/10/12 10:05 PM
09/10/12 10:05 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I had a very similar combo 2 years ago....
Let's not forget a dyno is only a dyno, it will not tell you how fast you will be going...or how quick your car will respond....
May be a bit short on cam duration, but my realistic guess will be 475hp and 480lbs tq at 4800rpm
you have very good quench with those pistons, so a very efficient combustion chamber...
One way or another, you'll have plenty of fun !!
Dan
'67 Barrcuda 6.75 1/8 mile
1970 SUper Bee
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: mshred] #1299451
09/11/12 08:31 AM
09/11/12 08:31 AM
RAMM Offline OP
RAMM  Offline OP
This engine HAS to turn 6700 rpm or it won't qualify in Ohio.
I have had plenty of experience with hydraulic rollers and zero issues with that kind of rpm level. The Scorpion lifters I am using this year are incredibly nice looking with a pushrod seat that is half an inch .5" higher than their solid rollers. The pushrod length on this particular combo is 7.2"--fairly short. With a set of PAC 1255's the rpm of 6700 should not be a problem. Whether or not it makes any meaningful power up there may be.J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299452
09/11/12 01:35 PM
09/11/12 01:35 PM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
568 hp @ 6200 rpm and 558 ftlbs @ 4200 rpm.
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: 79410aspenrt] #1299453
09/11/12 03:02 PM
09/11/12 03:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think this is real close
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: MR_P_BODY] #1299454
09/11/12 03:32 PM
09/11/12 03:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I think the "big" intake, and low compression will hurt torque more than most on here seem to think, but i am usually wrong...lol
Gonna say it will make " dragstrip" power equal to having 540 horsepower and 525 torque.
Dyno is so subjective it can say anything.
I would guess in a full weight 3300 pound A body its a 10.70-80 ish( 124 mph) motor in front of a 727.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: B3422W5] #1299455
09/11/12 04:01 PM
09/11/12 04:01 PM
RAMM Offline OP
RAMM  Offline OP
The dyno's in Ohio @ UNOH are not really subjective. There is no hiding behind "rigged" dyno results down there.
Thanks for the input though--we will see real soon. J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299456
09/11/12 06:53 PM
09/11/12 06:53 PM
Toronto
mshred Offline
mshred  Offline
Toronto
What's the highest rpms you have turned with the hydraulic rollers? do you always use the Scorpion lifters?
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299457
09/11/12 11:02 PM
09/11/12 11:02 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I think here's the weakest link. Put my guess in the 560HP/530TQ range.
Schoenfeld 1 5/8" 1 3/4" step headers with a 3.5 to 3" hillbilly merge
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Evil Spirit] #1299458
09/12/12 02:31 AM
09/12/12 02:31 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Arrington claims 630 ponies out of a 426 inch gen 3 using a much bigger hydraulic roller, little more compression, and a way better head that goes 370 cfm and a drag pack intake.
I didn't mean to imply dyno numbers aren't good for comparing different motors on same dunk, but same motor on different dyno can yield way different results that mean nothing except for tuning and checking for leaks
1.41 best 60 foot
6.60 at 103.90 1/8
