Page 1 of 5 1 2 3 4 5
Another --How much HP?---Engine dyno--416 stroker post #1299419
09/07/12 09:39 PM
09/07/12 09:39 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Here's the rundown:
360 block/half fill/line honed/decked, yadda yadda yadda.etc....
4" stroke 4340 Eagle crank with SCAT 6.123" rods
Icon 745's with a final static comp ratio of 10.5
Heavily worked EQ Magnum heads with 2.08"/1.60" flow 303-304 @ .630"
with a min CSA of 2.35" (wasn't easy)
Eddy SV with plenum work and port match .5 open spacer
Holley 830 or 1000hp with annulars
Hydro-roller 108 LSA 250/252 @ .050" .660"/.590" design (not actual)
Schoenfeld 1 5/8" 1 3/4" step headers with a 3.5 to 3" hillbilly merge
collector.
I have a great deal of faith that this combo will produce great power for what it is--What say you Moparts? J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299420
09/07/12 09:59 PM
09/07/12 09:59 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
603HP 546TQ. What do I win.....
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: W5DART66] #1299421
09/07/12 10:04 PM
09/07/12 10:04 PM
RAMM Offline OP
RAMM  Offline OP
Don't know yet but soon, very soon.
Gotta love ya Brett!
I like your guess (more like estimate) on HP but am searching for about 20 more ft/lbs.
At this point I am just really curious if I can get the FPS on the small ports down enough to get this many cubes to rpm enough. J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: W5DART66] #1299422
09/07/12 10:43 PM
09/07/12 10:43 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey... That was my guess
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299423
09/07/12 10:44 PM
09/07/12 10:44 PM
Renton Washington
Triple Threat Offline
Renton Washington
599.9
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299424
09/07/12 11:06 PM
09/07/12 11:06 PM
Delray beach, Florida
P
Performance Only Offline
P
so a couple are thinking along the lines of 1.45 hp/ cube. i would expect a bit less, more like 1.2hp/ cube. small HR cam with a small port will make great torque.
machine shop owner and engine builder
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299425
09/07/12 11:13 PM
09/07/12 11:13 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
570hp/540ftlbs.
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Performance Only] #1299426
09/07/12 11:16 PM
09/07/12 11:16 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
I say small port makes poor TQ (peek) and just not good for much of anything air speed in port just kills HP AND TQ.
I may have been tick aggressive on both my numbers on Robs dyno but I bet he gets close to the 600 HP.
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: W5DART66] #1299427
09/08/12 08:37 AM
09/08/12 08:37 AM
P
P
maybe i should have clarified what i said about making great torque by saying it will make great torque down low (2500-4000) the small port will surely hurt it.
as far as what it makes on the dyno, i hope it does well and he backs it up at the track.
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Performance Only] #1299428
09/08/12 08:40 AM
09/08/12 08:40 AM
RAMM Offline OP
RAMM  Offline OP
I am not sure if I will reach the 600hp benchmark with these heads; however, I am confident it will come very very close.
Dan--What would you consider a large hydraulic roller? J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299429
09/08/12 08:44 AM
09/08/12 08:44 AM
P
P
mid 260's and above.
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299430
09/08/12 09:37 AM
09/08/12 09:37 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i'd say low 500's comp is real low
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: fishy340] #1299431
09/08/12 09:45 AM
09/08/12 09:45 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
My engine masters 390 CI made 660 with 10.75to1...
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: W5DART66] #1299432
09/08/12 11:15 AM
09/08/12 11:15 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
560 moroso hp
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: W5DART66] #1299433
09/08/12 11:26 AM
09/08/12 11:26 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
o yea my indy junk made 700 w 950 carb on 93 octane na na lol
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: W5DART66] #1299434
09/08/12 11:36 AM
09/08/12 11:36 AM
RAMM Offline OP
RAMM  Offline OP
Rub it in why dontcha?
Just mocked up valvetrain--I'm impressed, actual lift at retainer is .663"/.590".
J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: RAMM] #1299435
09/08/12 01:07 PM
09/08/12 01:07 PM
SoCal
Brian Hafliger Offline
SoCal
555Hp and 530Tq.
Brian Hafliger
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Brian Hafliger] #1299436
09/08/12 02:17 PM
09/08/12 02:17 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
540 hp
480 lb/ft tq
Mo' Farts
Moderated by "tbagger".
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Brian Hafliger] #1299437
09/08/12 02:45 PM
09/08/12 02:45 PM
RAMM Offline OP
RAMM  Offline OP
555Hp and 530Tq.
I sincerely hope you're wrong! J.Rob
Re: Another --How much HP?---Engine dyno--416 stroker post [Re: Grizzly] #1299438
09/08/12 02:46 PM
09/08/12 02:46 PM
RAMM Offline OP
RAMM  Offline OP
540 hp
480 lb/ft tq
A stock stroke 360 can easily surpass 480 ft/lbs. I hope I didn't just step on my duck. J.Rob
