Holley acc pump issue. #1297180
09/04/12 12:35 PM
09/04/12 12:35 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
been helping a friend get his 70 AAR cuda running better, 6 pak is long gone and has been running a single 4 on it, he had a Edelbrock carb on it for a while, ran good but was a real bear to start after running it for a while, so switched to a Holley 650 dp he got from a friend, car ran, idled, and started much better after the swap but had a noticable stumble when you took off from a stoplight or anything, so we did the normal squirter swap,,nothing, changed the pump diaphragm,, nothing, even pulled it apart and checked the gasket and cleaned the circuit,,nothing what I did notice was when you give it a little throttle no gas came from the squirter untill you gave it more throttle so i took the squirter out and moved the throttle just a little and gas would come up in the main body but as soon as you released the throttle the level would drop as if it is draining back leaving a air gap between the main body and the squirter, so I put in a new check needle below the squirter and nothing,,all that I can think of is the check needle seat is mis machined or damaged(how I don't know) in the main body, can this be fixed or is it time for a new body? other than that the carb works excellent.
Re: Holley acc pump issue. [Re: dartman366] #1297181
09/04/12 01:04 PM
09/04/12 01:04 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Sounds more like the lever arm that engages the squirter is not adjusted correctly. Set the squirter arm to the adjustable bolt so that it barely touches or has a .004" gap, no more. Its the bolt that has a spring on it, and uses a 3/8" open end on both ends of it to adjust. Do the back one as well.
Re: Holley acc pump issue. [Re: Dragula] #1297182
09/04/12 01:48 PM
09/04/12 01:48 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
adjuster arm has been set and re set two different ways with the arm just barely touching and approx .015 clearance (additional travel) before bottoming out at full throttle, niether way had any effect, just don't understand why it bleed's back.
Re: Holley acc pump issue. [Re: dartman366] #1297183
09/04/12 02:19 PM
09/04/12 02:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Did you check the inlet check valve ? It is usually the flat red rubber type in the bottom of the carb under the pump. I only ask because to me when you have the pump discharge ball or weight in the circuit it will drop as soon as the pump stops to keep fuel right there and then the inlet check valve should open and let fuel in the circuit to keep a full and ready pump shot. Then of course the invlet valve should seat and seal so it has a full shot of fuel in the pump circuit. Ron
Re: Holley acc pump issue. [Re: 383man] #1297184
09/04/12 02:39 PM
09/04/12 02:39 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Make sure the rubber is laying flat and not dried/wrinkled up some. Also, the squirter check seat can be possibly straightened up with a small pin punch, set on top of the check needle, and then tapped with a hammer.
If you like drag racing, support your local track.
Re: Holley acc pump issue. [Re: CHAPPER] #1297185
09/04/12 02:55 PM
09/04/12 02:55 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
It's the older style check ball in the acc pump, wish it was the newer umbrella style as those are known to be quicker responding, thanks Fred I may look into that, got nothing to loose.
Re: Holley acc pump issue. [Re: dartman366] #1297186
09/04/12 04:07 PM
09/04/12 04:07 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
is the check needle under the squirter?
Re: Holley acc pump issue. [Re: dartman366] #1297187
09/04/12 05:37 PM
09/04/12 05:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow it seems every Holley I look at anymore has the newer umbrella type. Sorry I forgot about that. Ron
Re: Holley acc pump issue. [Re: 383man] #1297188
09/04/12 06:27 PM
09/04/12 06:27 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Did you check the bowl/ metering block gaskets? There isn't a whole lot of surface there.
Re: Holley acc pump issue. [Re: TRENDZ] #1297189
09/05/12 03:56 AM
09/05/12 03:56 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Yep check needle is there, I replaced it with a new on that I had,,gaskets all looked good as far as sealing but I replaced them anyway.
Re: Holley acc pump issue. [Re: dartman366] #1297190
09/05/12 10:11 AM
09/05/12 10:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What size squirter did you go to
Re: Holley acc pump issue. [Re: MR_P_BODY] #1297191
09/05/12 01:00 PM
09/05/12 01:00 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
it had a 25 we went to a 28 then 31 then 35 didn't change it always has to be pumped once before it shoots as if it's bleeding the fuel back and need's to be pumped back up to the squirter, I think it a bad seat in the main body thats allowing gas to bleed back and leaving a air pocket at the squirter.
