Question Scales 4 corners
#1297094
09/04/12 11:40 AM
09/04/12 11:40 AM
Posts: 1,505 TN
SCATPACK 1
TN
If you scale a 3200 lb B body with a big block and auto and 4 link in it. I know this is open to a lot of conjecture. But I need a starting point to shoot for. Assuming the weight bias is 55-45 front to rear. With the fat driver in the car, what would you shoot for at each corner.
Old Geezer Racing
Re: Question Scales 4 corners
[Re: MR_P_BODY]
#1297097
09/04/12 03:45 PM
09/04/12 03:45 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
There will be people telling you to screw on this and preload that to get the weights on each tire equal but I have never understood that. I would say put it together neutral and tune from there.
2011 Drag Pak Challenger
[Re: SCATPACK 1]
#1297100
09/05/12 12:52 PM
09/05/12 12:52 PM
dartman366
Mt. Vernon, Ohio
OK Another question, New to 4 links and want to be sure its right or close. Do you set the weight with the springs or do you preload the 4 link to get the weight you want on each wheel. For example, if the back right is less than the back eft, would you tighten up the left front spring or the right rear spring or both? IF you tighten up the right rear spring, does that shift more of the weight to the front wheels or does it just affect the right rear wheel. Or do you set all 4 of the springs the same and adjust the weight by putting pre-load into the 4 link bars? thanks again for your help.
I cannot answer anything as to 4 links but remember to have the car at race weight as if it's sitting on the starting line with you or someone or thing of your equal weight in the driver seat, I run a ladder bar car so I am watching this so to learn more about 4 links.
[Re: dartman366]
#1297101
09/05/12 06:32 PM
09/05/12 06:32 PM
Posts: 1,505 TN
SCATPACK 1
TN
Any other thoughts on setting the springs to even out the balance or using the bars tire load with??? thanks
Old Geezer Racing
[Re: SCATPACK 1]
#1297102
09/05/12 08:37 PM
09/05/12 08:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You leave the pre-loag ZERO till you get the weight set... if you mess with the left front it will move weight to the opposite corner(LF to RR).. once you get the car in shape and at ride height then you put in a small bit of pre load... different weight cars and the way they're built will require different pre loads.. mine uses 15# pre load
[Re: MR_P_BODY]
#1297103
09/06/12 12:02 AM
09/06/12 12:02 AM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
This is crazy .... i just finished doing this to my GTX I was hoping you could see the picture, it reads wgt 3832 w/ me 190lbs frt 50.5% rear 49.5% lft frt 1000 rgt frt 934 lft rear 974 rgt rear 924 my friend said dont touch a thing
[Re: MR_P_BODY]
#1297105
09/06/12 12:26 AM
09/06/12 12:26 AM
Posts: 88 Regina Sask, Canada
Viper469
Regina Sask, Canada
Right or wrong here's what we did. After making some initial passes(the car went hard right). We added some preload about 2 flats. Car still went right(not as bad). We scaled the car, approx #40 heavier on the LR. We then added #30 the the RR corner. Tried to lose as much #'s as we could find off the lt side, probbally #10-20. ended up at 1/2 turn of preload. Car went straight. Then we added nitrous. And right it went. Adjusted the RR spring perch up 1 1/2 turns, also adjusted the RF spring perch down 1 turn(mostly did this to get the car to sit somewhat level again). Then we just kept adjusting preload till it went straight. Ended up at 1 full turn. Food for thought. Adding weight buy adjusting LF spring isn't going to have much effect on the RR if the front wheels are in the air. Here' a pic after we got it sorted out. Pulls the wheels nice and even and goes nice and straight down the track. MY advise try and get more weight on the RR then the LT. Then adjust preload till it goes straight.
[Re: MR_P_BODY]
#1297106
09/06/12 01:08 AM
09/06/12 01:08 AM
10secGTX
Cleveland Ohio
Have you run it on the track yet EDIT The numbers dont have to be equal(nice if they are) but he may have added in weight already on the RR
This is how I've had for a year...it went 1.47 60' I'm lucky it hasn't gone left or right in any violent manner ....of course my wheelies are 2-4 inches off the ground.if that
[Re: 10secGTX]
#1297107
09/06/12 01:14 AM
09/06/12 01:14 AM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
Are you sure you dont have the rear numbers mixed up??
[Re: SB412DUSTER]
#1297108
09/06/12 01:19 AM
09/06/12 01:19 AM
MR_P_BODY
That would be my guess
[Re: MR_P_BODY]
#1297109
09/06/12 01:28 AM
09/06/12 01:28 AM
SB412DUSTER
Mobile Alabama
That or his friend had the rear wires pluged in the wrong scale.
[Re: dartman366]
#1297112
09/06/12 07:03 AM
09/06/12 07:03 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I wish my weights were that close. I scaled mine last weekend: DF 1144 PF 1056 DR 800 PR 732 Set up Billy Shope's traction dyno. One full turn of the right rear upper bar and I could get the passenger front tire coming off the ground first. Set it so both front wheels came up at the same time. Dave
[Re: quickd100]
#1297113
09/06/12 11:18 AM
09/06/12 11:18 AM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
Can't remember exact numbers but my 4-link a-arm tube car but they where equal lr rr rf and lf 60# more. I put 250# in drivers seat for me. I added 40# lead under bat box on rr and cranked up spring on lf till equal (not much)four link bars neutral. Then i got in the seat and while watching the digital scales turned the top right bar(had a panel i could remove) to take the slack out but not changing the numbers.It would hook on snot and go straight,2517# with me in it, 5.60 125 in the eight mile just clean the tires and go to line, bam gone.If you try to scale a ladder car you have to take out one bottom bolt on rear. Ladder will hold it in a bind if you don't,crank the springs in front then put the bolt back,done.Either way you want more weight on right rear tire(at launch it rotates lf to rr) its in the old Chrysler manuals.
