brake hoses #129685
09/29/08 07:39 PM
09/29/08 07:39 PM
NH USA
67_dart Offline OP
67_dart  Offline OP
NH USA
I put a 73 dart big bolt pattern on the front of my 67 dart with the calipers toward the rear someone said to use volare hoses? any certain year?
Mike
Re: brake hoses [Re: 67_dart] #129686
09/29/08 09:23 PM
09/29/08 09:23 PM
all volare's the same but if you ask for 78 you're set EDIT the metal bracket in the midle of the hose I would suggest that you cut half of it off & leave the piece that surrounds the hose as i'ts somewhat hard to get that off without damaging the hose & leaving it has no effect other than visual. I still had to bend the metal part of the hose to get mine to clear from lock to lock, be sure & check.
