Leaky valve covers... #1295573
09/02/12 09:33 AM
09/02/12 09:33 AM
nj
MoJoe Offline OP
MoJoe  Offline OP
nj
I just can't get my valve covers to stop leaking. I have a 383 with stock heads... it leaks pretty on the passenger back outboard side and runs down the bell housing. I 've tried different gaskets, sealants...just when I think I have it licked it comes back. Looking at the top of the head, the gasket surface is very narrow and a little rounded... almost a ridge. Should'nt this area be a little wider and flat? It looks like it could be a bad casting...any how it leaks pretty good and short of getting a new head I don't know what to do. Any ideas? Thanks
Re: Leaky valve covers... [Re: MoJoe] #1295574
09/02/12 09:52 AM
09/02/12 09:52 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Go get some superformace gaskets and the GRAY rtv sealant. Put a thin film on the head surface. Also look at the valve cover surface and see if there are casting marks. If so, fill in with the gray rtv. Make sure you get the gray kind. That blue, orange, black and whatever color they make is garbage.
Re: Leaky valve covers... [Re: Todd] #1295575
09/02/12 10:09 AM
09/02/12 10:09 AM
nj
MoJoe Offline OP
MoJoe  Offline OP
nj
Super performance...any suggestions. Thanks
Re: Leaky valve covers... [Re: MoJoe] #1295576
09/02/12 10:16 AM
09/02/12 10:16 AM
PA USA
flatiron Offline
flatiron  Offline
PA USA
I've had real good luck with the Mr Gasket Ultra Seals
Re: Leaky valve covers... [Re: flatiron] #1295577
09/02/12 03:57 PM
09/02/12 03:57 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
A tall intake might need the lips of the v/c to be relieved. Damhik
Re: Leaky valve covers... [Re: radar] #1295578
09/02/12 05:47 PM
09/02/12 05:47 PM
Castlegar, BC, Canada
That AMC Guy Offline
Permatex "The Right Stuff".
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Leaky valve covers... [Re: MoJoe] #1295579
09/02/12 07:51 PM
09/02/12 07:51 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Have you checked to make sure the covers aren't bent from being over tightened in the past? Take them off and remove the gasket, Is the surface that seals against the gasket flat and NOT dimpled down where the bolts are? If they are dimpled, you carefully beat them back to flat.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Leaky valve covers... [Re: That AMC Guy] #1295580
09/02/12 08:14 PM
09/02/12 08:14 PM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
I second that, it solved my valve gasket leaks.
B5 Challenger T/A
Re: Leaky valve covers... [Re: KARLN] #1295581
09/03/12 01:12 AM
09/03/12 01:12 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
As long as you never need to take a valve cover back off. IF you do guaranteed to be bent by the pry bar it takes to remove it.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Leaky valve covers... [Re: kilroy] #1295582
09/03/12 01:22 AM
09/03/12 01:22 AM
I've used Permatex Ultra Blue.
It stops leaks but like others have said, getting the valvecovers off can be difficult!
Re: Leaky valve covers... [Re: That AMC Guy] #1295583
09/04/12 08:19 AM
09/04/12 08:19 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
Right on! I had real good luck with the ROL hi-per blue VS5877HP gaskets. Make sure the covers are straight and clean, use brake clean on both covers and block. I put a small amount of Permatex on the cover, attach the gasket then bolt to the engine, without Permatex on the engine side. Do not overtighten the bolts, the covers bend easily, lightly snug them. I go around and lightly snug them yearly when cold.
Re: Leaky valve covers... [Re: 63stabamatic] #1295584
09/05/12 07:50 AM
09/05/12 07:50 AM
Lexington NC
twinscrew698 Offline
Lexington NC
I heard Cometic valve cover gaskets was good!
Although i never have used them, some here on Moparts have!
A little more in money but if it stops the leaks it might be something to think about!
