A small setback #1295229
09/01/12 06:16 PM
09/01/12 06:16 PM
robertop Offline OP
robertop  Offline OP
I was handling the power steering pump for my Roadrunner and I dropped it, causing a dent in the reservoir Where can this thing be repaired? It's making a noise when I turn the pulley, so something is touching where it should not. Another day in the resto business, I guess....
Re: A small setback [Re: robertop] #1295230
09/01/12 07:47 PM
09/01/12 07:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The can/resivour will pop off from the back. Beat the dent flat and reinstall.
You remove the bolts and pressure port nut on the back and carefully remove over the large 0-ring.
Read the repair manual and you can get a reseal kit for pretty reasonable (come with front seal too).
Re: A small setback [Re: autoxcuda] #1295231
09/01/12 08:22 PM
09/01/12 08:22 PM
Yep, re-seal kits from Autozone are around $11.00 last I checked. Very easy to R&R the pump at home!
