glad you got it running and had no issues
as for the "happy dyno" part.....
based on the BSFC numbers and fuel flow, it was making around 513hp uncorrected.
and the sheet shows an almost 15% correction factor.....which really seems a bit too high to me.
the sheet also shows a baro press of 29.8, so its doesnt seem like the dyno is located at a place where the elevation is real high.
i dont see why the correction would be nearly 15%.
i dont know if ive ever even seen 10% down here.
its usually between like 2.5% and 7.5%.
assuming you ran it down here, and it made the same 513hp uncorrected(in similar air as to what you had up there), and that day happened to be as bad as a 7.5% day........the corrected numbers would have been just over 550hp.....which is really more like what i would have expected.
EDIT- after crunching some of the numbers off that sheet.....they dont really work out correctly.
236.1lbs/hr of fuel, and a BSFC of .46 works out to 513.26hp.
however, 513.2 X C/F of 1.148 only comes out to 589.1....not 609.
609/ 1.148 is 530.4, not 513.2
236.1/530.4= .445.....not .46
so.....not a lot from that sheet makes much sense to me.
sometimes the decimal isnt carried out far enough on the BSFC number, which will skew the results a couple of HP......but not like the 15-20 i'm seeing here.
this is just an example of why the only dyno numbers i really care about are the ones i get myself.
