Re: Building my first set of headers, got some ???
[Re: MR_P_BODY]
#1293676
08/31/12 12:16 PM
08/31/12 12:16 PM
Posts: 2,578 sweden
1Fast340
sweden
I welded some pieces of 1x2 steel together and ground off the corners and then tapered it to form the ends of the tubes. I just use a torch to heat and form them, although pressing them like Mike does sounds a bit faster!
LOL... when I was in the lab I could do all 8 in less than 2 minutes... made it super easy... thats why I suggest going with the 1" fine thread on the end of the sizing tool... you can get a exhaust shop to do it for $5 or they might do it for free
lol threading that 1"fine thread sounds exhausting, i would prefer getting a Huth quickchange fitting instead that way it just slips right into the quickchange slot
it´s an option but not all that important was just joking a bit since i´m a litle lazy and have been working abit to much with threaded parts today at work on a huthbender using the thread is slightly better compared to the quickchange in reality,since its more stable.
[Re: 1Fast340]
#1293677
08/31/12 12:31 PM
08/31/12 12:31 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Can I add one thing, before you send them out to be coated (if you do), add egt and O2 bungs to each tube. I know that seems excessive but if you every put the engine on a dyno or add a data recorder, you will get some valuable information.
Joe
Without Data, you’re just another guy with an opinion.
[Re: CrAzYMoPaRGuY]
#1293678
09/01/12 02:58 AM
09/01/12 02:58 AM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Anybody built headers with merge collectors for a street car?
CrAzYMoPaRGuY
[Re: 69dart]
#1293680
09/01/12 09:07 PM
09/01/12 09:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just had a set of headers built for my roadster last week. I used these flanges http://www.jegs.com/i/JEGS+Performance+Products/555/31835/10002/-1 from Jegs and the 1 7/8th underchassis header kit. They turned out extremely nice but the guy had 40 hours of labor in building them.
Under chassis headers range between 30 to 40 hours (at least for me)
[Re: MR_P_BODY]
#1293681
09/01/12 10:22 PM
09/01/12 10:22 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Aside from Mr. Peabody's method, what other approach can be used to get the pipe formed to match the port shape in the flanges? To make it even tougher, the small blocks have some odd shaped exhaust ports.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1293682
09/01/12 10:49 PM
09/01/12 10:49 PM
MR_P_BODY
Using a steel rod and a hammer... lay the rod into the tube and hit the rod NEAR the tubing(holding the other end of the rod)
[Re: DusterDave]
#1293685
09/01/12 11:20 PM
09/01/12 11:20 PM
MR_P_BODY
What diameter do you suggest for the steel rod?
What ever the smallest radius is... on the SB about 3/4" rod would be close
[Re: rt66jim]
#1293688
09/02/12 09:07 AM
09/02/12 09:07 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Thanks for the info, guys! It sounds to me its going to be a lot less work and hassle for a beginner like me if I start out with the flanges that have the stubs on them.
