Mopar Engine experts:Please i need Help!........UPDATE #1293560
08/29/12 10:02 AM
08/29/12 10:02 AM
Lexington NC
twinscrew698 Offline OP
Lexington NC
I am stumped on this problem,i picked up this 68 RR a couple of weeks ago and drove it home about 150 miles on back roads running anywhere from 35 MPH to 65 MPH and had no problems in the engine.
However i developed a sound in the motor area that sounded exactly like a Fan belt squeal or alt bearing squeal and changed Alt with one from NAPA and also changed belts..still there after the change!
So next thing i thought Water Pump,Changed that and still squeals..
So i was stumped again and thought OK lets try it w/o any belts on P/S and Alt...Still squeals..
Now Finally i am done for a few days with it,so i put in a OIl Prssure Gauge to Keep an eye on Pressure and on start up it is almost at 80LBS and as u can see in Video Here starts up fine and no squeal.
I was using the old hose trick to find any small unheard squeals in engine compartment.This is a Cold start from overnight sitting.
http://s1260.photobucket.com/albums/ii566/twinscrew698/?action=view&current=IMG_2129.mp4
Sorry about the video Quality and whistling sound as i was working by myself and trying to get the IPHONE to sit up by itself.
Then as u can see after a few minute warmup it started to squeal in this video.
http://s1260.photobucket.com/albums/ii566/twinscrew698/?action=view&current=IMG_2130.mp4
Then after about ten minutes in this video.
http://s1260.photobucket.com/albums/ii566/twinscrew698/?action=view&current=IMG_2131.mp4
I have been told a few things that could cause this but figured i would see if any one else has had this happen to them!
Any help would be helpful to me if you can!
Re: Mopar Engine experts:Please i need Help! [Re: twinscrew698] #1293561
08/29/12 10:53 AM
08/29/12 10:53 AM
I know you changed the WP but take its' belt off (1 minute max) just long enough to see if that's it. Might be an issue with the round oil slinger down on the crank snout. Any possibility it's coming from the rear (torque converter) area?
Re: Mopar Engine experts:Please i need Help! [Re: RapidRobert] #1293562
08/29/12 11:12 AM
08/29/12 11:12 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
get it warmed up and take the belt off. to me it sounds like belt squeal
take it off if it's gone tighten belt "better" and maybe put some belt dressing on.
Re: Mopar Engine experts:Please i need Help! [Re: twinscrew698] #1293563
08/29/12 12:22 PM
08/29/12 12:22 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Without a belt on the alternator that would mean no belt on the water pump , or did the OP get a short belt that just fit on the waterpump and crank pulley ?
Re: Mopar Engine experts:Please i need Help! [Re: JohnRR] #1293564
08/29/12 01:26 PM
08/29/12 01:26 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
as said above, my first thought was oil slinger put on backwards.
Re: Mopar Engine experts:Please i need Help! [Re: 65rbdodge] #1293565
08/29/12 01:45 PM
08/29/12 01:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is that a belt rub mark I see on the water pump pulley snout?
Re: Mopar Engine experts:Please i need Help! [Re: twinscrew698] #1293566
08/29/12 02:04 PM
08/29/12 02:04 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Do you have a fan clutch on it? Could be on the way out. Sounds like mine did just before the fan went through the radiator.
Re: Mopar Engine experts:Please i need Help! [Re: R/T1968R/T] #1293567
08/29/12 02:26 PM
08/29/12 02:26 PM
Lexington NC
Lexington NC
RapidRobert:
I did take belts off completly and let it run for about a min!No Belts at all!
Am gonna Check Converter Next when i have someone here to help.
Dodgem:
Done all of that!
JohnRR:
Correct no belts at all!!
65rbdodge:
Gonna have to look at that!
Stumpy:
Noise still with belts off.
R/T1968R/T:
Yes it does have a fan clutch on it,That was another thought but run the engine w/o Belts hooked up so clutch was not turning.
Gonna check on T/C when i get some help to put it up on ramps and start it!
Then maybe go into the oil slinger after the weekend!
Thanks for he input all,if any one else chimes in it is something i can check out later..
Re: Mopar Engine experts:Please i need Help! [Re: twinscrew698] #1293568
08/29/12 05:44 PM
08/29/12 05:44 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
too much timing will also make your water pump squeal like a pig when you rev. i have no clue why but mine does that. back the timing down and it goes away!
Re: Mopar Engine experts:Please i need Help! [Re: mikemee1331] #1293569
08/29/12 05:53 PM
08/29/12 05:53 PM
Lexington NC
Lexington NC
Thanks for the reply,but i think i have it narrowed down to the area of the timing chain so i am thinking it is the oil slinger as earlier stated.
I will start tearing it down next week and give an update if i find out the problem!
Thanks all for the help!
Re: Mopar Engine experts:Please i need Help! [Re: twinscrew698] #1293570
08/29/12 09:57 PM
08/29/12 09:57 PM
GMP440 Offline
GMP440  Offline
Had this similar problem on my friends 68 Roadrunner after we broke in the 383. We were hearing a loud squeeling at the front of the engine. Well it turned out that the the new bolts that were used to
mount the pulley on the crankshaft, were too long causing the bolts to scrape against the timing case cover. We put in the correct length bolts and no more squeeling.
This may or may not be causing your problem, but it's something to check.
Re: Mopar Engine experts:Please i need Help! [Re: GMP440] #1293571
08/30/12 05:21 AM
08/30/12 05:21 AM
North America
2002bluert Offline
2002bluert  Offline
North America
I had the same problem on 440 in a 71 Challenger the bolts were just a thread to long and once it warmed up they touched the cover just enough to make a very loud squeal. Shorter bolts is all it took.
Re: Mopar Engine experts:Please i need Help! [Re: 2002bluert] #1293572
08/30/12 07:27 AM
08/30/12 07:27 AM
Lexington NC
Lexington NC
Going to check those bolts out as well,as he had really long bolts on the fan clutch that was on it so it is a good chance he done the same!
Something else to look at when i take it apart!
Thanks GMP440 and 2002blurt...
Re: Mopar Engine experts:Please i need Help! [Re: twinscrew698] #1293573
08/30/12 10:13 PM
08/30/12 10:13 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
it not the bolts since it still making the same noise when the belts are off! I'm want to go with the oil slinger.
Re: Mopar Engine experts:Please i need Help! [Re: BigTerry] #1293574
08/30/12 11:38 PM
08/30/12 11:38 PM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
check the timing cover, to see if it's bowed out ,and toouching the balencer. I had this happen,and changed a waterpump for no reason.
Re: Mopar Engine experts:Please i need Help! [Re: 72sat] #1293575
08/31/12 01:58 AM
08/31/12 01:58 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Re: Mopar Engine experts:Please i need Help! [Re: MoparMarq] #1293576
08/31/12 12:29 PM
08/31/12 12:29 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Are u capable of removing the distributor. You might have a top bearing going or gone. Just a thought though .
Re: Mopar Engine experts:Please i need Help! [Re: MoparMarq] #1293577
08/31/12 06:52 PM
08/31/12 06:52 PM
Me too!
Re: Mopar Engine experts:Please i need Help! [Re: RapidRobert] #1293578
09/04/12 07:51 AM
09/04/12 07:51 AM
Lexington NC
Lexington NC
Ok now that i am back in town,i will be tearing this down in the next few days and taking all of your suggestions!
Has had my family members stumped too as i showed them the video that i took with my phone so we will see!
Took it apart as you can see the oil slinger was hitting the timing cover as it had a little bit of play to it so it was moving around a bit also!
Re: Mopar Engine experts:Please i need Help! [Re: twinscrew698] #1293579
09/04/12 06:31 PM
09/04/12 06:31 PM
Lexington NC
Lexington NC
Also i dont know if it was the wrong one but i had one still in a 440 i had laying around and here is the difference!
The one i took out that is on the left and the old one i had on the right!
