I.D. This Air Cleaner? #1292729
08/28/12 12:25 PM
08/28/12 12:25 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Can anyone let me know the application for this air cleaner?
Re: I.D. This Air Cleaner? [Re: 70mopes] #1292730
08/28/12 01:28 PM
08/28/12 01:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Looks similar to the one on my 69 Chrysler 300, 440/4bbl
Re: I.D. This Air Cleaner? [Re: DAYCLONA] #1292731
08/28/12 01:32 PM
08/28/12 01:32 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Dayclona,
Does your aircleaner have the pointed center like this one or does it accept a pie tin?
Re: I.D. This Air Cleaner? [Re: 70mopes] #1292732
08/28/12 01:46 PM
08/28/12 01:46 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: I.D. This Air Cleaner? [Re: WINGCARS_6970] #1292733
08/28/12 02:34 PM
08/28/12 02:34 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Nick's air cleaner page does not cover this type of assembly.
Re: I.D. This Air Cleaner? [Re: 70mopes] #1292734
08/28/12 02:42 PM
08/28/12 02:42 PM
TX , NJ , FL
W
W
TX , NJ , FL
Re: I.D. This Air Cleaner? [Re: 70mopes] #1292735
08/28/12 02:47 PM
08/28/12 02:47 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
66 bib block air cleaner.
Re: I.D. This Air Cleaner? [Re: WINGCARS_6970] #1292736
08/28/12 02:50 PM
08/28/12 02:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'm guessing '66-'67 c-body w/4bbl - here's a '68 Imperial air cleaner & it has the pie tin sized center.
The "divot" next to the snorkle is also different. What Chrysler "TNT" engine used the sticker instead of a pie tin.
Re: I.D. This Air Cleaner? [Re: 6bblgt] #1292737
08/28/12 02:56 PM
08/28/12 02:56 PM
TX , NJ , FL
W
W
TX , NJ , FL
Was thinking Polara line
http://www.google.com/imgres?q=1966+383&...&ved=1t:429,r:2,s:0,i:78
Re: I.D. This Air Cleaner? [Re: 70mopes] #1292738
08/28/12 03:15 PM
08/28/12 03:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What size is the carb throat on the base , 2bbl , AFB or AVS ? Is the snorkel end round or rectangular ?
Re: I.D. This Air Cleaner? [Re: JohnRR] #1292739
08/28/12 07:13 PM
08/28/12 07:13 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
It is in route. It is an oval snorkel. It was said to be for a 4 barrel however the base plate it has in not original to the assy. It has the volcano top which does not accept pie tins. That look was around on '68 air cleaners but I personally have not seen it on other year assemblies. The C- body pic above best matches it however it accepts a pie tine which leaves me still scratching my head.
Re: I.D. This Air Cleaner? [Re: 70mopes] #1292740
08/28/12 07:30 PM
08/28/12 07:30 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'66 Imperial with hose to oil fill breather was this CA only?
Re: I.D. This Air Cleaner? [Re: 6bblgt] #1292741
08/28/12 07:32 PM
08/28/12 07:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'66 Imperial with out hose to oil fill breather
Re: I.D. This Air Cleaner? [Re: 6bblgt] #1292742
08/28/12 07:33 PM
08/28/12 07:33 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'67 Imperial with "pie tin" top
Re: I.D. This Air Cleaner? [Re: 6bblgt] #1292743
08/29/12 03:59 PM
08/29/12 03:59 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Ok.. cool. '66 C-body (maybe others?) which would require a base fitting a Carter AFB carb.
Now I am wondering what air cleaner '66 B-bodies with A/C would have used.
Thanks all for your inputs.
Re: I.D. This Air Cleaner? [Re: 70mopes] #1292744
08/29/12 04:36 PM
08/29/12 04:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What carb ? But I'll go out on a limb and say the same one as pictured above .
