How much of a beating can a 23 spline take???
#1292633
08/28/12 12:38 AM
08/28/12 12:38 AM
Posts: 3,415 Toronto
mshred
Toronto
What is it? Im not talking about granny shifting, or hard street driving which is pretty much all tire spin...Im talking straight powershifting, beat the snot outta it track cars.
My 3400lb pig was running 11.80's before the motor just ate a bearing, and I was also going to spray it but not sure if the transmission can handle it...was aiming for high tens, and still using my centerforce dual friction clutch
So I would like to hear how fast you went/how much power, weight of the car, clutch, gear, tire, etc. Just trying to see if it is still worth trying to get a 23 spline to live up to the added power, or if I will be running it on borrowed time
Re: How much of a beating can a 23 spline take???
[Re: HPMike]
#1292635
08/28/12 02:38 AM
08/28/12 02:38 AM
Posts: 399 metro detroit
turner
metro detroit
I had one in my 65 Satellite, 3600lbs, 440, 4 speed, 4:10 geared, would 60' at 1.54 and run 11.30's, also had the 11" centerforce dual friction and a lakewood housing, 28x10 MT slick..........I could never break mine and it was a street car and I would drop the clutch at about 3500 off the line
[Re: mshred]
#1292636
08/28/12 02:56 AM
08/28/12 02:56 AM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Had a 23 spline in a few cars my buddy street raced.
THEY CAN TAKE A BEATING.
Make no mistake about it, For decades I watched one of the best speed shifters on the planet street race. Foot to the floor, yank the gears. Day after day after day.
He had brand new 18 spline transmissions, wouldn't consider using them. He would ONLY use a 23 spline 4 speed, and it HAD to have a scattershield and a pistol grip shifter.
CrAzYMoPaRGuY
[Re: scatpacktom]
#1292640
08/28/12 07:22 PM
08/28/12 07:22 PM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
OH, they can take a real beating right up till one of the speed gears seizes to the mainshaft and you go through the traps with the wheels locked up at 120 mph and the track has to winch your car up on a rollback and when you get back to your pit spot they slam the bed back and forth till your car "comes off" and then you are stuck with a car 20 feet from where it needs to be with no real good way of getting it there.
That sounds like experience talking, had to suck to be you that day.
[Re: mike67net]
#1292641
08/28/12 09:11 PM
08/28/12 09:11 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have ran 23 spline 833's for over 40 years mostly in racing applications and never heard of gears seizing on the shafts. I have broke input shafts, out put shafts and 3rd gear cluster & main gear. As power goes up you will find that the 3rd gear will push away from itself and boom, you got a gunk transmission, did that 3 times. Now run a Liberty pro shifted Doug Nash, I broke that to, shifting into 2nd with the wheels in the air puts allot of stress on 2nd gear, about $1300.00 worth :
[Re: mshred]
#1292643
08/28/12 11:59 PM
08/28/12 11:59 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
all I can say is that what I am hearing is not sounding too comforting, although I still dont have a ballpark idea of how much they can take
The answer is easy..
About as much power as a bone stock 340 or 383 puts out.
All kidding aside, not to belabor the point, but the FACTORY felt that all 440/426's got 18 spline trans'...That should give you some indication of how much faith the guys with the horn rimmed glasses and pocket protectors thought, anyway.
Yes, as stated, the 23 spline is pretty tough, but why push the envelope? Heck, the prices on good used 18 spline gears, clusters and input shafts have come way down now that you can buy them in the aftermarket. I recently bought a good used Hemi trans for 600 for a customer. Or you can use your case, synchro assms and main shaft. All you need is a matching gearset a set of bearings, a gasket kit and small parts. Building the trans is about the easiest thing you can do on one of these....
MB
[Re: mshred]
#1292644
08/29/12 09:10 AM
08/29/12 09:10 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Why don't you spray it and tell us? None of the guys above have said they are on the juice so their stories only partly help, your clutch may or may not, I'll eer on the side of not, handle the hit of spray so the trans will hold up just fine I would think ...
Buy a couple of spare transmissions and clutches and take them to the track with you .
[Re: Paul_Fancsali]
#1292647
08/29/12 03:21 PM
08/29/12 03:21 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Lets think about this for a second, Its the input shaft thats a fine spline, 23, vs an 18 spline. So really the tranny behind it is the same, only different ratios, but the basic trans is the same. So unless your snapping off, or buzzing the splines bald, they in theory can take as much as an 18 which is a heck of a lot of abuse. A far superior 4 gear than that of any GM, or Ford ever came with. Thats why they were transplanted into so many Camaros, Chevelles, and muskrats back in the day.
I pound the hell out of the tranny in the Demon, and I know there has been a few in this area that got a far worse beating than I can put on one.
[Re: Moparnut426]
#1292648
08/29/12 03:32 PM
08/29/12 03:32 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Sorry, but you're wrong....
18 spline gears are bushed and the teeth are heavier and have more root thickness. The pitch is even different. Other than the mainshaft, case and sychro assms, they are as different as cats and dogs...
MB
[Re: HPMike]
#1292649
08/29/12 03:33 PM
08/29/12 03:33 PM
Moparnut426
MB
Thanks, didnt know about the bushed gears.
Learn something every day, but the basic design is the same is it not?
[Re: Moparnut426]
#1292650
08/29/12 04:42 PM
08/29/12 04:42 PM
JohnRR
U.S.S.A.
MB
The design is the same but the gears are different and that is why the 18 spline is stronger than a 23 spline, as Mike said.
[Re: cudadoug]
#1292652
08/29/12 07:32 PM
08/29/12 07:32 PM
mshred
Toronto
Hey guys, thanks for all the input! I love racing and driving the stick, but I really want to throw some serious power at this thing on the spray (or possibly stroke it and spray it...engine is coming out again this winter to deal with a bearing issue I had at the last outing). Im just worried that with what I want to do (high tens or faster) that its going to be on borrowed time- my car isn't exactly light, and I powershift the hell out of it, using a non adjustable pressure plate. I already have a backup trans that I keep fresh just in case (had to use it already this year when my main one had a cracked third gear synchro), but if im throwing too much power where it breaks all the time, a spare wont do me good.
I was thinking about an adjustable clutch, but not sure how close I can get it setup without a data logger, and it seems like its the 2-3 gear change that seems to be the weak point for this transmission, so not sure how much the adjustable would help that
18 splines are just too ridiculous in price to buy and convert for an a-body, and to have 2 would be even crazier- I would be better off with a race transmission like a Jerico/G-force of some sort, but those are serious coin used as well, and I would need a new clutch, bell, and shifter also...Gosh does being addicted to speed suck on the financial side of things lol
